Akif's avatar
Akif
Mar 05, 2020
F5-sdk on Python
I'm trying to implement a project with f5-sdk on python.
I'm working on a F5 BIG-IP device.
I want to get the current throughput and number of connections data so that i can make a simple dashboard.
I can get number of connections data for each virtual server but i need to see the data about the whole system.
How can i do this? Which functions,classes i can use. Documentation doesn't really helped me to achieve this.
Can you give example code parts?
Thanks all.
  • I believe you can get the information from 'tmsh show sys tmm-traffic'. The command provides the traffic data per tmm, so you need to sum them up. The iControl REST endpoint for this command is /mgmt/tm/sys/tmm-traffic.
    • Akif's avatar
      Akif
      Thank you for your answer, it really saved me here. iControl REST endpoint works perfectly.
