Nizar's avatar
Nizar
10 months ago
Solved
CLI Command to Identify Wide IPs Using L4 vs L7 Monitors
Hi Everyone,
I would like to ask if there is a CLI command or script that I can run on my BIG-IP GTM to grep the following:
Which Wide IPs are still using pools with Layer 4 health monitors (e.g., tcp, tcp-half-open)?
Which Wide IPs are already using pools with Layer 7 health monitors (e.g., http, https)?
Any guidance or assistance would be greatly appreciated.
Thank you very much.
  • Hi Nizar​
    Try below script:
    echo "=== Wide IPs using L4 Monitored Pools (tcp, tcp-half-open) ==="
    for pool in $(tmsh list gtm pool one-line | grep -E 'monitor (tcp|tcp-half-open)' | awk '{print $3}'); do
    echo "Pool: $pool"
    tmsh list gtm wideip one-line | grep "pool $pool"
    done
    echo
    echo "=== Wide IPs using L7 Monitored Pools (http, https) ==="
    for pool in $(tmsh list gtm pool one-line | grep -E 'monitor (http|https)' | awk '{print $3}'); do
    echo "Pool: $pool"
    done
    Reference:  K000149309: How to display a list of wide IPs with corresponding pools and pool member IP addresses?
  • Hi Nizar​
    Try below script:
    echo "Pool: $pool"
    done
    echo
    echo "Pool: $pool"
    done
