Sinan's avatar
Sinan
Ret. Employee
Feb 25, 2020
f5 sdk can't load pool objects after create pool.
Hi experts:
I can't load a pool object after I created it.
from f5.bigip import ManagementRoot
from f5.bigip.contexts import TransactionContextManager
if __name__ == "__main__":
    for x in range(1, 50):
        mgmt = ManagementRoot('10.5.10.23', 'admin', 'XXXXX', token=True)
        tx = mgmt.tm.transactions.transaction
        with TransactionContextManager(tx) as api:
            name = 'pool' + str(x)
            api.tm.ltm.pools.pool.create(name=name, partition='Common')
            p = api.tm.ltm.pools.pool.load(name=name, partition='Common')
            p.delete()
            api.tm.util.bash.exec_cmd(
                command='run',
                utilCmdArgs="-c 'tmsh save sys config'"
I got this error:
Traceback (most recent call last):
  File "/Users/sinwang/PycharmProjects/Suzhou_Beer_CMCC/f5_sdk_transaction.py", line 31, in <module>
  File "/Users/sinwang/PycharmProjects/Suzhou_Beer_CMCC/venv/lib/python2.7/site-packages/f5/bigip/resource.py", line 1110, in load
    return self._load(**kwargs)
  File "/Users/sinwang/PycharmProjects/Suzhou_Beer_CMCC/venv/lib/python2.7/site-packages/f5/bigip/resource.py", line 1084, in _load
    response = refresh_session.get(base_uri, **kwargs)
  File "/Users/sinwang/PycharmProjects/Suzhou_Beer_CMCC/venv/lib/python2.7/site-packages/icontrol/session.py", line 295, in wrapper
    raise iControlUnexpectedHTTPError(error_message, response=response)
icontrol.exceptions.iControlUnexpectedHTTPError: 404 Unexpected Error: Not Found for uri: https://10.5.10.23:443/mgmt/tm/ltm/pool/~Common~pool1
Text: u'{"code":404,"message":"01020036:3: The requested Pool (/Common/pool1) was not found.","errorStack":[],"apiError":3}'
  • What happens if you use CURL instead of your script? Do you still get the same 404 error?
  • Hmmm... and the pool is definitely created and saved if you check with tmsh and in the config file?
    • Sinan's avatar
      Sinan
      Ret. Employee
      We should create a new transaction. A transaction does all of the config together, as one transaction. Therefore you can’t load it before the transaction has been committed.
  • So reviewing your script...
    Why the 3rd line? p.delete() ?
    p.delete()
    • Sinan's avatar
      Sinan
      Ret. Employee
      I want to delete the pool after created it.
  • Okay. In that case, for that work you need to modify your script.
    First confirm whether you can create a single pool and delete via curl. This is just my sanity check.
    Next confirm you can create a single pool and delete via Python using those Libraries.
    I would restructure the code to make it more simple/logical. I understand the for loop to create the different pool names. Maybe try using a list comprehension to create the pool name. And then iterate through the list.
    Next. I believe the code is failing as the p.delete() is being executed within the loop where you are creating pool names.
    Actually looks like you have two loops here. The for loop and when you do the with part... That is also a kind of loop.
    I would create a function to create your pools and then a function to check the pools are in place and then create another function to delete the pools.
    Does that make sense?
  • Here's a rough of what I meant... Not finished and no error checking, but I will leave the excitement of figuring out to you :-)... Devcentral does not handle me pasting code in so well here (had to manually put indentation back in. But there you go...
    pool_names = ['pool' + str(x) for x in range(1, 50) ]
    def pool_create():
    for name in pool_names:
       command='run',
    def pool_list():
    def pool_remove():
    • Sinan's avatar
      Sinan
      Ret. Employee
      import threading
      import time
      def create_pool(name):
          print time.ctime() + "create pool name: %s" % name
              api.tm.ltm.pools.pool.create(name=name)
      def delete_pool(name):
          print time.ctime() + "delete pool name: %s" % name
              p = api.tm.ltm.pools.pool.load(name=name)
              p.delete()
      def save_config():
          print time.ctime() + "save sys config"
                  command='run',
              # x = threading.Thread(target=create_pool, args=(name,))
              # x.start()
              # # time.sleep(1)
              # x = threading.Thread(target=delete_pool, args=(name,))
              # x.start()
              # time.sleep(1)
              # x = threading.Thread(target=save_config)
              # x.start()
              # time.sleep(1)
              create_pool(name)
              delete_pool(name)
              save_config()
      Tested this code,​ it works.
