Sam10's avatar
Sam10
Jul 10, 2019
Solved
F5 need to same data to different nodes on a same vip
can i terminate tls connections on f5 and then f5 need to send same data to 2 different nodes. Is this possible.
  • Hello Sam.
    You have the iRule already explained here
    https://devcentral.f5.com/s/articles/http-request-cloning-via-irules-part-1
    The idea is to use High Speed Logging to send a clone of the initial packet to another set of servers (pool).
    Other idea is to use sideband connections with the HSSR feature.
    https://clouddocs.f5.com/api/irules/HTTP-Super-SIDEBAND-Requestor-Client-Handles-Redirects-Cookies-Chunked-Transfer-APM-Access-etc.html
    Everything depends on your scenario.
    BTW, I would appreciate if you mark my answer as the best or give me some upvotes.
    Thanks.
    KR,
    Dario.
  • Hello Sam.
    There are some approaches that can vary depends on your topology and goal. I recommend you to check this out.
    • SSLO - https://youtu.be/AadhUC5FNGs
    • Interface Mirroring/Pool Clonning - https://support.f5.com/csp/article/K13392
    • IRules for Packet Duplication - (1) https://devcentral.f5.com/s/articles/http-request-cloning - (2) https://devcentral.f5.com/s/articles/udp-tcp-packet-duplication
    KR,
    Dario.
  • Dario thanks for your response.
    If go with this option how is cloning going to work across 2 servers. Can you help me understand the logic
    rule http_request_clone_one_pool {
    when RULE_INIT {
    set static::hsl_debug 1
    set static::hsl_pool "my_syslog_pool"
    when CLIENT_ACCEPTED {
    if {[active_members $static::hsl_pool]==0}{
    log "[IP::client_addr]:[TCP::client_port]: [virtual name] $static::hsl_pool down, not logging"
    set bypass 1
    return
    set bypass 0
    set hsl [HSL::open -proto TCP -pool $static::hsl_pool]
    if {$static::hsl_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: New hsl handle: $hsl"}
    if {$bypass}{
    return
    HTTP::header insert X-Forwarded-For [IP::client_addr]
    if {[HTTP::method] eq "POST"}{
    if { [HTTP::header Content-Length] >= 1 and [HTTP::header Content-Length] < 1048576 }{
    HTTP::collect [HTTP::header Content-Length]
    } elseif {[HTTP::header Content-Length] == 0}{
    HSL::send $hsl "[HTTP::request]\n"
    if {$static::hsl_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Sending [HTTP::request]"}
    when HTTP_REQUEST_DATA {
    set request_cmd "HTTP::request"
    if {$static::hsl_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Collected [HTTP::payload length] bytes,\
    sending [expr {[string length [eval $request_cmd]] + [HTTP::payload length]}] bytes total"}
    HSL::send $hsl "[eval $request_cmd][HTTP::payload]\nf"
    • Dario_Garrido's avatar
      Dario_Garrido
      Icon for Noctilucent rankNoctilucent
      Hello Sam.
      Thanks.
      KR,
      Dario.
