Bartosz_Krajews
Oct 23, 2020F5 LTM health monitor to check IBM DB2 master or slave node
Hello,
Using F5 LTM health monitor how to check which IBM DB2 in the pool is master and which is slave? Which monitor to use for it?
Is there a way to do it using http monitor?
Thanks a lot.
that depends on if there i a different response form a webpage on the master or the slave? is there perhaps such an url you can request?
