eLeCtRoN's avatar
eLeCtRoN
Icon for Cirrus rankCirrus
Feb 12, 2024
F5 iRule for Header insert
Hello,
I create that iRule below, but my header value for the header x-id is still empty, what could be wrong ?
foreach header_name [HTTP::header names] {
if {([HTTP::header value $header_name] eq "x-id")} {
set VALUE [HTTP::header "XXX#YYYY" ]
HTTP::header insert "x-id" $VALUE
kind regards
eLeCtRoN
  • it seems you want to replace the header value with something else? What do you want to accomplish exactly?
    You can try this.
    if { [HTTP::header exists x-id] } {
    set VALUE [HTTP::header "XXX#YYYY"]
    #log command to determine if VALUE is set correctly
    log local0. "x-idlog var VALUE=$VALUE"
    # header x-d allready exists -> remove it first.
    HTTP::header remove x-id
    # add header x-id with variable VALUE
    HTTP::header insert x-id $VALUE
    The problem might be the var VALUE is not set correctly, and is thus empty.
    • eLeCtRoN's avatar
      eLeCtRoN
      Hello Cypher,
      our header x-id is empty per default and the WAF doesen't like that and blocks our request, so I want to set a value
      for the header x-id, now I set your iRule active and the header is still empty, in the system log I got just the messages
      HTTP:header insert x-id $VALUE
      syslog-nglog local0. \"x-idlog var VALUE=$VALUE\"
      • Cypher's avatar
        Cypher
        i would troubleshoot 'bottom-up' and use lowercase for variables (not sure if that has an impact, but it is a good practice).
        i don't know what XXX#YYYY is, but it needs to exists as a header, or whatever you use instead of XXX#YYYY. so lets see if it exists first in the logs.
        log local0. "$header_name"
        set value [HTTP::header "XXX#YYYY"]
        log local0. "x-idlog var value=${value}"
        # header x-id allready exists -> remove it first.
        # add header x-id with variable value
        HTTP::header insert x-id $value
        check system > logs > local traffic for errors and logs.
  • Hi eLeCtRoN do you also have a header named XXX#YYYY? If not, then that's going to be an empty value anyway. If you are trying to:
    1. Assure the x-id header exists
    2. Assure that the x-id header has a value
    Then, something like this should work for you:
    when HTTP_REQUEST priority 500 {
        if { [HTTP::header exists x-id] && ([HTTP::header x-id] == "") } {
            HTTP::header replace x-id "some value here"
            HTTP::header insert x-id "some value here"
    if you don't need the header to be there then you can eliminate the else statement altogether.
    • eLeCtRoN's avatar
      eLeCtRoN
      Hi Jason,
      just short tell you what I have, I have form the application the header x-id with no value inside (empty), so my WAF policy don't like that and block the request, what I now want to do is just to set a value inside the header x-id. Thanks for your response
      • JRahm's avatar
        JRahm
        Icon for Admin rankAdmin
        then that should work for you as is, or without the else block.
