Lyonsy_271608's avatar
Lyonsy_271608
Mar 24, 2017
Solved
Irule problem "contains then insert"
Hi Guys,
Looking to add an irule to fix a code issue until it can be fixed by the software team
when a request is made that contains native-billing i would like it to insert header named x-version with the value of 9.0
we have tried
when HTTP_REQUEST { if {{ [HTTP::uri] contains "native-billing" }} { HTTP::header insert "X-Version" "'9.0'" }
didnt work Any ideas
thanks is advance
  • Do you get any error when adding the iRule to the system? Do you get any error when the iRule is executed?
    I don't see any major error in the iRule, except the double {. However, that shouldn't cause problems.
    Try add some log messages, like this:
      log local0. "[HTTP::uri]"
      if { [HTTP::uri] contains "native-billing" } {
        log local0. "Header inserted"
      log local0. "Headers: [HTTP::header names]"
  • figured it out didnt like the "'9.0'"
    Changed to this and works
    when HTTP_REQUEST { if { [HTTP::uri] contains "native-billing" } { HTTP::header insert "X-Version" "9" } }
