steulet_87932's avatar
steulet_87932
Mar 05, 2009
F5 Installation problem
Hi guys,
I'm using windows XP sp3 and I'm not able to install the firepass plugin:
INSTALLATION:
SSL VPN Driver installed
IP Filter Driver installed
RAS check failed
Host DLL registration failed
VPN Dialer DLL registration is OK
urxhost.dll installed
urxdialer.dll installed
PINGs test:
Address name www.f5.com passed
IPAddress = 65.61.115.222 passed
Loop back 127.0.0.1 passed
Gateway address = 172.21.42.254 failed
Gateway address = 172.21.39.254 passed
DNS address = 172.16.34.1 passed
DNS address = 172.16.34.5 passed
SERVICEs test:
DHCP Client:Running
Network Connections:Running
DNS Client:Running
Remote Access Connection Manager:Running
F5 VPN driver:Stopped
I uninstall everything with f5wininfo and I tried to reinstall the plugin: Now I've the following error
A connection to the remote computer could not be established. You might need to change the network settings for this connection. For further assistance, click More Info or search Help and Support Center for this error number.
Thanks for your help, best regards
Greg
  • I've got exactly the same problem. Did you get a solution for this problem / I will open up a case...
  • Hello,
    I have the same problem - does anybody have a solution for this?
    Marko
  • Hi, I bet if you look in the logterminal.txt file for the computer you will see a line such as:
    CDialer : : OnCallback : Error occurred =720
    The devilish 720 error is a Windows error and not a Firepass VPN Client error. I have run into this several times and have gone through the hoops with F5 support.
    There are several things that can cause this. F5 support has some great troubleshooting info, but none if it has fixed this problem for me.
    Instead I hit up the Interwebs and found several things that have worked.
    First thing to check is device manager. Click View -> Show hidden devices then expand the Network Adapters section and look for "WAN Miniport" devices with errors. That's a bad sign and they will need to be fixed.
    If you don't have any errors with your WAN Miniport devices then a barbarous and bloody manual delete and reinstall of the WAN Miniport drivers may do the trick. This has solved the "error 720" problem for me on several occasions. I am not making guarantees or telling you to do it; I am merely speaking of my own experiences supporting the F5 VPN Client on thousands of computers where it's not optimal to suggest reloading the OS instead.
    Here's a URL that describes the process I have used with success:
    http://shorttipsandtricks.blogspot.com/2009/05/error-720-connection-to-remote-computer.html
