LucasP's avatar
LucasP
Oct 08, 2019
Solved
iapps f5.automated_backup problem
Hello,
I'm using the iapps f5.automated_backup version 2.0.3 (I know it is an old one), the apps is working great, I use it on a test and a prod cluster.
But since few days the app on the prod cluster stopped working, it doesn't run the backup on the configured schedule.
When I try to check the configuration going on the iapps and clicking "reconfigure" the config never show up, I have the message "Loading...
Receiving configuration data from your device." indefinitely.
Anybody know what I can try to solve the problem ? Is there a service I can restart or something like that ? I suppose that a a full reboot could solve the problem but as it is a production device I'm trying to find another way to solve the problem.
thanks for your help !
Lucas
  • Hi LucasP,
    Any log in /var/log/ltm?
    Scriptd deamon may have issues. You can try restart it.
    bigstart restart scriptd
  • Hi LucasP,
  • LucasP's avatar
    LucasP
    Hi eaa,
    Thank you very much for the tips ! It worked, I can now see the config, I will reschedule the backup and see if it also working.
    Thank again
    Lucas
  • LucasP's avatar
    LucasP
    to answer your question, no I was not seeing anything in the logs.
