F5 chassis memory usage
In F5 chassis we are having two memory 1. TMM 2. Other What is the use of TMM and other, For our chassis other memory is showing 99% always. How we can reduce?
- Dineshsankar_31
Altostratus
in this chassis we are using 2 VCMP for our env.
- Nazir_52641
Cirrus
Hi Dinesh, Can you share the output of the following command: tmsh show sys memroy - eben
Hi Dinesh, Also share the output of "tmsh show /sys tmm-info" How much RAM is alotted to each VCMP Guest?
- Vijay_E
Cirrus
I think you are talking about "OS Used" memory. That tends to remain high. It shouldn't affect normal functioning.
- Dineshsankar_31
Altostratus
Sys::TMM: 1.0Global TMM Process Id 12707 Running TMM Id 0 TMM Count 1 CPU Id 0
Memory (bytes) Available 3.7G Used 286.0M
CPU Usage Ratio (%) Last 5 Seconds 7 Last 1 Minute 7 Last 5 Minutes 7
- Dineshsankar_31
Altostratus
The VIP configuration and pools details nodes details where it is saving in F5?
means which location which file ?
