AhmadZak's avatar
AhmadZak
Dec 21, 2019
F5 BIG-IP 2000 Series Power standby mode when turning it on
I have got a F5 WAF Big-IP 2000. It give on the LCD screen it says "Power Standby Mode. Press Enter to Command Power On" when i turn it on. I have tried to press the green button but the F5 logo blinks once and goes dark again. I found a solution online that mentioned to hold the green check button on the LCD panel for a second to get the device out of stand by mode. Tried this as mentioned earlier but nothing.
Can you please help?
Thanks!
  • Hi AhmadZak,
    It appears that we have two articles about this. I would recommend reading through each of them and then trying the steps in the second article. If that doesn't work then I would recommend opening a ticket with Support to continue troubleshooting and possibly RMA the device depending on the troubleshooting results.
    K77265211: Device is not able to boot with error message: "Power standby mode Press Enter to command power on"
    https://support.f5.com/csp/article/K77265211
    K43323300: Error Message: Power Standby press Check button to command power on
    https://support.f5.com/csp/article/K43323300
    -Nathan F
