Ameet_Patel_601's avatar
Ameet_Patel_601
Oct 18, 2010
External Monitor Causing CPU to Spike
Hello,
We run a set of HTTP streaming servers behind an F5 Virtual Server/Pool. Due to the HTTP streaming specification, we have to send video in 30 seconds increments. As such we need a monitor on the pool to disable a member node instead of marking it as down to allow for current streams to continue but not allow new connections to be made. We use an external monitor to check a web page that is hosted on each of the pool members. Basically it's a binary check of text on a webpage to return a 0 (means enable the pool member) or 1 (disable the pool member). However when we run the monitor we notice via top command I see load on the F5 spike up to 6 or 7 and as high as 12-15. This causes connections to be dropped frequently from the F5. There are roughly 25 members in the pool this monitor is assigned to. We run the monitor every 30 seconds with a timeout of 90 seconds. Does anyone have any idea as to what we can do to less the CPU load on our F5? Below is the code written for our external monitor.
-------------------------------------------------------BEGIN MONITOR----------------------------------------------------------------------
!/bin/bash
=================================DESCRIPTION=======================================
This monitor scans for the HTTP Streaming Server Shutdown flag, and if found, it
disables the node. If not found, it re-enables the mode.
This is DIFFERENT than saying the node is UP or DOWN.
A "down" node will have persistence table entries erased, but a "disabled" node will
not. So this "monitor" always reports a node as being "up", which means it should
NOT be used as a health check.
This script needs to be installed in /usr/bin/monitors and a health monitor
of type EAV configured to use it, with the following arguments set:
NODE_ADDR - Implicit first parameter
NODE_PORT - Implicit second parameter
POOL_NAME - The name of the pool that will be checked.
=================================START OF SCRIPT=======================================
---------------------------NON-USER-MODIFIABLE VARIABLES-------------------------------
STARTTIME=`date +%s%N`
PIDFILE="/var/run/monitor_$1..$2.pid"
NODE_ADDR=`echo $1 | sed 's/::ffff://'`
NODE_PORT=`echo $2`
POOL_NAME=`echo $3`
if [ "$POOL_NAME" == "" ]
then
POOL_NAME=`echo all`
fi
------------------------END OF NON-USER-MODIFIABLE VARIABLES---------------------------
----------------------------------HOUSEKEEPING-----------------------------------------
PIDFILE stores the process id of this script to avoid multiple runs.
Kill last instance if still running, and update so script can be killed on hang.
[ -f ${PIDFILE} ] && kill -9 `cat $PIDFILE` 2> /dev/null
echo "$$" > $PIDFILE
-------------------------------END OF HOUSEKEEPING-------------------------------------
-------------------------------BEGIN SCRIPT LOGIC--------------------------------------
Send a GET request to the server and parse the response for the Shutdown=0
RESPONSE=`echo "GET /mcdata HTTP/1.1\r\nHost: \r\nConnection: Close" | /usr/bin/nc $NODE_ADDR 5700`
RESPONSETIME=`date +%s%N`
TIMETORESPONSE=$((( $RESPONSETIME - $STARTTIME ) / 1000000 ))
ALIVE=`echo $RESPONSE | grep "DVC Server"`
SHUTDOWN=`echo $RESPONSE | grep "Shutdown=1"`
QUERYTIME=$RESPONSETIME
output=""
if [ "$ALIVE" != "" ]
then
cmd=""
ISENABLED=`b pool $POOL_NAME member $NODE_ADDR:$NODE_PORT show | grep enabled`
QUERYTIME=`date +%s%N`
if [ "$SHUTDOWN" == "" ]
then
if [ "$ISENABLED" == "" ]
then
output=`echo "up - $NODE_ADDR:$NODE_PORT should be enabled"`
cmd=`echo "b pool $POOL_NAME member $NODE_ADDR:$NODE_PORT session enable"`
else
output=`echo "up - $NODE_ADDR:$NODE_PORT is already enabled"`
fi
else
if [ "$ISENABLED" != "" ]
then
output=`echo "up - $NODE_ADDR:$NODE_PORT should be disabled"`
cmd=`echo "b pool $POOL_NAME member $NODE_ADDR:$NODE_PORT session disable"`
else
output=`echo "up - $NODE_ADDR:$NODE_PORT is already disabled"`
fi
fi
Issue the pool member command
if [ "$cmd" != "" ]
then
`$cmd`
fi
fi
COMMANDTIME=`date +%s%N`
TIMETOQUERY=$((( $QUERYTIME - $RESPONSETIME ) / 1000000 ))
TIMETORUN=$((( $COMMANDTIME - $QUERYTIME ) / 1000000 ))
TIMETOTAL=$((( $COMMANDTIME - $STARTTIME ) / 1000000 ))
DEBUG CODE
echo Inputs: NodeAddr: $NODE_ADDR, NodePort: $NODE_PORT, PoolName: $POOL_NAME >> /tmp/disable_shutdown_mon.log
echo Response: == $RESPONSE == >> /tmp/disable_shutdown_mon.log
echo Alive: == $ALIVE == >> /tmp/disable_shutdown_mon.log
echo Shutdown: == $SHUTDOWN == >> /tmp/disable_shutdown_mon.log
echo Enabled: == $ISENABLED == >> /tmp/disable_shutdown_mon.log
echo Command: $cmd >> /tmp/disable_shutdown_mon.log
echo Output: $output >> /tmp/disable_shutdown_mon.log
echo Time\(ms\): resp=$TIMETORESPONSE, qry=$TIMETOQUERY, cmd=$TIMETORUN, tot=$TIMETOTAL >> /tmp/disable_shutdown_mon.log
END DEBUG CODE
if [ "$output" != "" ]
then
Now, echo up command to standard output
echo $output
fi
Clean up the working files and exit cleanly.
rm -f $PIDFILE
exit
-------------------------------END SCRIPT LOGIC----------------------------------------
================================END OF SCRIPT==========================================
-------------------------------------------------------END MONITOR-------------------------------------------------------------------------
  • hoolio's avatar
    hoolio
    Hi Ameet,
    That looks pretty good. I don't see a lot that can be made much more efficient. Here are a few suggestions:
    - comment out the TIME calculations if you're not debugging the monitor.
    - consider not checking the current state before enabling/disabling the pool member--just enable/disable it
    - replace the echoes with direct assignments:
    NODE_PORT=`echo $2`
    POOL_NAME=`echo $3`
    NODE_PORT=$2
    POOL_NAME=$3
    POOL_NAME="all"
    And after anything is sent to standard output, the script is killed. So I don't think the removal of the pidfile will ever happen. You could add a removal above the echo $output statement.
    Aaron
