Jean-Francois_7
Jul 20, 2012Expire Certificate issue
Hi all,
The certificate defautl in the LTM in SSL certicate list had expired. I renewed the certificate default to 9125 days.
When I return to the menu of all the certificates, the date is expired but if I validate the certificate, there is a new date.
I do the following command and I see the new date
openssl x509-in / config / ssl / ssl.crt / default.crt-noout-enddate | cut-c10-40 .....
I wanted to delete the file / config / ssl / ssl.crt / default.crt but it is used in templates
We use the V11.2
Does anyone has had this problem
Cheers
Jean-Francois
- Techgeeeg
Have to tried to rename this file instead of deleting it and rename the other file as default.crt.... - nitass
Employee
yes, i got it too. it is similar to sol13381 but modify file ssl-cert command is not working. if no one else here knows or has any idea, could you please open a support case?
sol13381: The 'tmsh install sys crypto cert' command fails when you attempt to install a renewed SSL certificate
http://support.f5.com/kb/en-us/solutions/public/13000/300/sol13381[root@ve11a:Active:Changes Pending] config openssl x509 -in /config/ssl/ssl.crt/default.crt -dates -noout notBefore=Jul 20 16:55:40 2012 GMT notAfter=Jul 20 16:55:40 2013 GMT root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list sys crypto cert default.crt sys crypto cert default.crt { certificate-key-size 2048 city Seattle common-name localhost.localdomain country US email-address [email protected] expiration Jun 28 15:21:16 2022 GMT organization MyCompany ou IT state WA subject-alternative-name } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list sys file ssl-cert default.crt sys file ssl-cert default.crt { certificate-key-size 2048 checksum SHA1:1334:4c5fe8d2d4006c3a02be05242218f401cd601ad5 create-time 2012-06-30:16:07:12 created-by root email [email protected] expiration-date 1656429676 expiration-string "Jun 28 15:21:16 2022 GMT" issuer [email protected],CN=localhost.localdomain,OU=IT,O=MyCompany,L=Seattle,ST=WA,C=US key-type rsa-public last-update-time 2012-06-30:16:07:12 mode 33188 revision 1 serial-number 911 size 1334 subject [email protected],CN=localhost.localdomain,OU=IT,O=MyCompany,L=Seattle,ST=WA,C=US system-path /config/ssl/ssl.crt/default.crt updated-by root version 3 } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) modify sys file ssl-cert default.crt source-path file:/var/tmp/default.crt Copying file "file:/var/tmp/default.crt" ... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 101 1216 101 1216 0 0 5185k 0 --:--:-- --:--:-- --:--:-- 0 01070712:3: Caught configuration exception (0), Access check failed for (/Common/default.crt). - sys/validation/FileObject.cpp, line 3095. - David__Pasch
Altostratus
I recently had this issue and had to force a reload of mcpd to resolve it. sol13030 can show you how to do this.
Hope it helps!
David
