Viv_Richards's avatar
Viv_Richards
8 years ago
Duplicate URI redirection issue
we have URI redirection configured as below Internet URL- https://www.abcd.com/test/xyz Intranet URL-
Internet URL- https://www.abcd.com/testhij/xyz Intranet URL-
Along with this, we have client source IP based restriction at "/testhij/xyz"
As shown above since "xyz" URI exists in both URLs.
iRule1 used is as below when HTTP_REQUEST {set newuri [class match -value [HTTP::uri] equals DATAGROUP-REDIRECT ]} iRule2 used is as below
switch -glob [string tolower [HTTP::uri]] { "/xyz" { pool XYZ_pool } "/xyz" { if { [class match $forwarded_ip equals WIFI ] } { Process the traffic pool HIJ-Pool } else { drop
Datagroup "DATAGROUP-REDIRECT" defines
STRING: /testhij/xyz VALUE :/xyz
and
STRING: /test/xyz
VALUE :/xyz
Since URI "/xyz" is exist in both the request, we are not getting expected output.
Is there anyway, we can make it working ? Appreciate in advance.
    1. Please post again the code here with right format (select the whole code and press TAB key, look in the Preview below the text if it is readable)
    2. We can't read in your head, can you please explain with examples what is the expected output and ;-)
    3. Why are you configuring 2 different irules instead of a merged code?
  • URI redirection issue we have URI redirection configured as below Internet URL- https://www.abcd.com/test/xyz Intranet URL- Internet URL- https://www.abcd.com/testhij/xyz Intranet URL- Along with this, we have client source IP based restriction at "/testhij/xyz" As shown above since "xyz" URI exists in both URLs.
     2. Set host as will be used to rewrite hardcoded http redirection links
    set host [HTTP::host]
    if { [HTTP::uri] equals "/" } {
     HTTP::uri "/reb/"
    set newuri [class match -value [HTTP::uri] equals dg_redirect ]
      log local0.info "uri is [HTTP::uri]"
     if {$newuri ne ""} {
     HTTP::respond 302 Location "https://[HTTP::host]$newuri" Connection Close
        TCP::close
        event disable
        log local0. "[HTTP::uri] redirected to $newuri"
        unset newuri
         "bypass" tracks whether or not we made any changes inbound so we
         can skip changes on the outbound traffic for greater efficiency.
        set bypass 1
         Initialize other local variables used in this rule
        set orig_uri "[HTTP::uri]"
        set orig_host "[HTTP::host]"
        set log_prefix "VS=[virtual name], Host=$orig_host, URI=$orig_uri"
    set clientside ""
    set serverside ""
    set newpool ""
    set ppass ""
    Source_IP_Detection_Option_28_Start
        if { [IP::version] == 4 } {
                set OPTION_28_IP [TCP::option get 28]
                if {[string length $OPTION_28_IP] > 0 } {
                        set forwarded_ip [IP::addr parse $OPTION_28_IP 0]
                        log local0. "IP Found in TCP Option 28: $OPTION_28_IP"
                        log local0. "Length Error in TCP Option 28 raw value: $OPTION_28_IP"
        log local0. "URI = [string tolower [HTTP::uri]]"
        log local0. "Client IP SNAT = [IP::client_addr]"
        log local0. "Client IP = $forwarded_ip"
    Source_IP_Detection_Option_28_Stop
    if {! [class exists $clname]} {
        log local0. "$log_prefix: Data group $clname not found, exiting."
                pool $default_pool
        return
        set ppass [class match -element "$orig_host$orig_uri" starts_with $clname]
        if {$ppass eq ""} {
             Did not find with hostname, look for just path
            set ppass [class match -element "$orig_uri" starts_with $clname]
        if {$ppass eq ""} {
                 No entries found
                if { $static::ProxyDebug > 0 } {
    log local0. "$log_prefix: No rule found, using default pool $default_pool       and exiting"
                                         "/xyz*" { pool xyz_pool }
                     "/xyz*" {
    Process the traffic
    pool xyzhij_pool
    Drop Connection
    HTTP::respond 200 content "Apology   PageAccess Denied"
     log local0. "Non wifi IP detected and connection dropped"
    Pool xyzhij_pool
    From internet if URL requested as https://www.abcd.com/test/xyz, it should redirect to https://www.abcd.com/xyz and it should reach to so that it will be processed properly.
    From internet if URL requested as https://www.abcd.com/testhij/xyz and if it is coming from specific source IPs then only it should get redirected to https://www.abcd.com/xyz and it should reach to so that it will be processed
    In current scenario, since /xyz is overlapping, I would like overcome this overlapping
