Drop connection for ActiveSync based on URI Query
Hi Guys,
If i need to drop the connection for "POST" /MS-Server-ActiveSync based on parameter value for URI query (EX: DeviceNO = xxx)
I did the following but without success using fiddler
if { [string tolower [HTTP::uri]] starts_with "/Microsoft-Server-ActiveSync" } {
set test [URI::query [string tolower [HTTP::uri]] DeviceNo]
if { !([class match $test equals DeviceNo-DG]) } {
log local0. "blocked"
drop
log local0. "blocked2"
DeviceNO-DG is configured using "String DATA Group" with the needed DEVICENO
Any suggestion
Hi MR.Freddy,
string tolower: Returns a value equal to string only that all upper case values are converted to lower case.
You should not use tolower or change string:
[string tolower [HTTP::uri]] starts_with "/microsoft-server-activesync"- MR_Freddy
Thank you for your reply , so my irule is correct after modifying this part ?
I think it will work correctly when you also change the following line.
set test [URI::query [HTTP::uri] DeviceNo]
