Nolan_Jensen
2 years agoDos Attacks not showing on dashboard
Issue:
DoS attacks are not showing on the DoS dashboard.
Information:
- Strange part is this was working but then I made a few changes to split this particular virtual server into internal and external VIPs only apply DoS profile to external VIP.
- I have a DoS logging profile enabled on this VS
- I know attacks are happening as I can see them under Security > Event logs > DoS > Application Events
- However, any of the new attack ids don’t show under the DoS Dashboard located Security > Reporting > DoS > Dashboards
Any thoughts on how to fix would be much appreciated?
Thanks!
Hi Nolan_Jensen,
I recommend you open a support case, I have other issues with dashboards in the F5 for the WAF module, and all of these problems are related to bugs, probably support can recommend you a version to fix this issue.
Hope it works.
- Nolan_Jensen
Will do. Thank you for the response!
