stetu_237492's avatar
stetu_237492
Jun 01, 2017
disabling monitoring for pool member
I'm converting a system implemented in Java from iControl to iControlREST and I'm having difficulties finding how to disable the monitoring for a pool member.
With iControl you can set the a LocalLBPoolMemberMemberSessionState to iControl.CommonEnabledState.STATE_ENABLED or iControl.CommonEnabledState.STATE_DISABLED to do so.
But from the iControlREST API, it's not so clear, as the "session" cannot be changed from "monitor-enabled" to "monitor-disabled".
I know I can turn the pool member offline and online again by setting a combination of "session" and "state" as indicated here:
https://devcentral.f5.com/articles/icontrol-rest-working-with-pool-members
But I can't seem to figure out how to replicate the behavior of iControl to only disable monitoring.
Thanks in advance to anyone who can point me in the right direction...
    • stetu_237492's avatar
      stetu_237492
      I'd like to be able to toggle on/off monitoring for a pool member.
      I know it's possible to see the state of the monitor with a GET request to the REST Api through /mgmt/tm/ltm/pool/THE-POOL/members/THE-MEMBER/stats
      Ex: ....."entries":{........."monitorStatus":{"description":"up"}..........}
      But I don't if it's possible to formulate a valid JSON string to change a value with a PUT request to modify stats (as it would make sense that they're read-only).
      stetu_237492
