Paul_Slater
14 years agoCreating an External Monitor in a partition
I am trying to get the NTP monitor working in a partition without much success.
I know that the config of the monitor is correct without any partition information as we have a Virtual F5 which I used to confirm that the Monitor responds and this is working fine.
I copied across the files from this virtual but the monitor fails so I can only presume that thepartion needs to be entered somewhere but where?
I took the standard NTP monitor on DEV Central as my base and removed the comments as it threw an error on line 48 but after the comments were removed the cli and the monitor worked straight away. can anyone shed some light?
- David_20660
Hi Paul,
This is a bit ugly, and we've bastardized the original NTP monitor on Dev central but it seems to work thus far....
!/usr/bin/perl -w
use lib "/config/monitors/CPAN";
use strict;
use Net::NTP;
Add this PM to /config/monitors/CPAN/Net
use Net::IP;
require 5.005;
Derive and untaint programname.
my $programname = '/' . $0;
$programname =~ m/^.*\/([^\/]+)$/;
$programname = $1;
if ($programname eq '') {
die "Bad data in program name\n"
Process ID and file where it's to be stored. The format
is significant.
my $node = $ENV{"NODE_IP"};
my $port = $ENV{"NODE_PORT"};
my $pidfile = "/var/run/$programname.$node..$port.pid";
my $pid = "$$";
Maintenence. Clean up any existing EAV.
if (-f $pidfile ) {
open(PID, "<$pidfile");
my $pid = ;
close(PID);
if ( $pid ) {
chomp $pid; $pid =~ m/^(\d+)$/; $pid = $1;
if ( $pid ) {
kill 9, $pid;
unlink($pidfile);
Create a new maintenence file.
open(PID, ">$pidfile");
print PID $pid, "\n";
close(PID);
Create $ipv6 variable to change the $node IPv6 address
to an 'un-shortened' IPv6 address ($fullipv6)
my $ipv6 = new Net::IP ($node);
my $fullipv6 = $ipv6->ip();
Running "bigpipe db bigd.debug enable" can see "addr=2620:0:c10:f501:0:b:a20:97f6:123" when trying to test export (export
NODE_IP="2620:0:c10:f501:0:b:a20:97fa" NODE_PORT="123") - the script failed.
However, if used an IPv4 address it worked, tested on a virtual f5 debugging showed it
was using IPv4 - assumed this was because we were using partitions on production
boxes???
took off the first 6 IPv6 octets as when debugging found this was the same for all
addresses in the pool (this may be different on your box - partition name etc) - the last 2
octets of NODE-IP converted from hex to dec equalled our IPv4 addresses.
$fullipv6 =~ s/2620:0000:0c10:f501:0000:000b://;
removed the colon between the 2 last octets
$fullipv6 =~ s/://;
pulled apart the $fullipv6 string into 4 variables ready to convert into decimal
my ($v1, $v2, $v3, $v4) = unpack 'A2A2A2A2', $fullipv6;
convert each of the hex (IPv6 Octet) variables into decimal
my $ipv4v1 = hex($v1);
my $ipv4v2 = hex($v2);
my $ipv4v3 = hex($v3);
my $ipv4v4 = hex($v4);
my $dec = ".";
create the IPv4 address from the above variables with decimals
my $ipv4addy = ($ipv4v1 . $dec . $ipv4v2 . $dec . $ipv4v3 . $dec . $ipv4v4);
put in the IPv4 address in the place of the old $node variable
if (try_ntp_test($ipv4addy,$port)) {
print "OK\n";
unlink($pidfile);
exit(0);
substituted the $node variable with the $ipv4addy variable
sub try_ntp_test {
we just make sure we get a response
and that the server isn't a stratum
16 server (ie, it's lost it's time source).
my ($ipv4addy,$port) = @_;
my %response;
eval {
%response = get_ntp_response($ipv4addy,$port);
if ($@) {
return 0;
if ($response{'Stratum'} =~ /\d+/) {
changed to drop the member if their stratum was 14 or higher
if ($response{'Stratum'} >= 14) {
return 0;
and it isn't 16
return 1;
return 0;
} - David_20660
2620:0:c10:f501:0:b:a20:97f - Looks like the 'b' matches the partition id (in this case 11)
And the first/48 bits are allocated to f5..
NetRange: 2620:0:C10:: - 2620:0:C10:FFFF:FFFF:FFFF:FFFF:FFFF
CIDR: 2620:0:C10::/48
OriginAS: AS22317
NetName: SEA-HQ
NetHandle: NET6-2620-C10-1
Parent: NET6-2620-1
NetType: Direct Assignment
RegDate: 2008-02-29
Updated: 2012-02-24
Ref: http://whois.arin.net/rest/net/NET6-2620-C10-1
OrgName: F5 Networks, Inc.
OrgId: F5NETW
Address: 401 ELLIOTT AVE W
City: SEATTLE
StateProv: WA
PostalCode: 98119
Country: US
RegDate: 1999-09-24
Updated: 2011-09-24
