James_78615's avatar
James_78615
16 years ago
Create zonefile records on GTM using TMSH
Is it possible to create SOA records on the GTM using the command line tmsh?
I can create a new WIP with the following:
tmsh
gtm
create wideip test.example.com pools add { Test_Pool }
However, the above commands use the GTM hostname for the SOA details such as 'Master Server' and 'Email Contact'.
Instead of using the internal hostname, I want to create the SOA and NS records using a globally available domain name.
I can do this using Zonerunner from the web GUI but I want to be able to script it from the command line.
There is the following method that describes making modifications to the zonefile but I would prefer something from the tmsh that does not require manually freezing the zonefile:
https://support.f5.com/kb/en-us/solutions/public/5000/700/sol5739.html
James
  • Mark_Crosland_2's avatar
    Mark_Crosland_2
    Historic F5 Account
    There is currently no tmsh interface into the zonerunner/named/bind database. It is on a roadmap.
    • TomL_122341's avatar
      TomL_122341
      Hi, is this still on the roadmap or has this been released? I have been searching for an answer to this specific question and almost gave up until I found this thread. Thanks, Tom
  • Gents, I know that this isn't exactly what you're looking for, but if you're handy with iControl, you can add a second step to your plan and write/run a script that will change the SOA values for you. Check out Management::ResourceRecord::update_soa in the iControl wiki. I use scripts to add/delete/modify A and MX records now instead of the GUI.
    Even with the initial development time for the scripts, I've saved countless hours by not having to use the GUI. I can provide code samples in Perl because that's what I write in, but any other language and you're on your own.
    • jg_abaitua's avatar
      jg_abaitua
      Hello Faintly Lucky, can you please also let me see your perl scripts for managing DNS records over CLI?
    • neenee_208438's avatar
      neenee_208438
      Same here, Faintly Lucky. Can you provide some perl samples?
      jg_abaitua
      neenee_208438
  • I also wanted to control zonerunner. Specifically to create 'static' resource records like MX and TXT records. I stumbled across a little shell that seems to be what does the work for the configuration gui: zrsh. Variables, designated @VariableName@, are injected from my management tool- below are some examples of the format.
    @Zone@ = 'example.com'
    @EscapedZone@ = 'example\.com'
    @RecordType@ = 'MX'
    @DesiredRecords@ = '"external example.com. example.com. 3600 MX 10 smtp.example.com." "external example.com. example.com. 3600 MX 20 smtp1.example.com." "external example.com. example.com. 3600 MX 20 smtp2.example.com."'
    @Authority@ = 'dns.example.com'
    Here's the script I ended up with:
    !/bin/sh
    ZoneFile=/tmp/newzone.external.@Zone@.
    Zone=@Zone@
    RecordType=@RecordType@
    ZoneExists=0
    DesiredRecords=(@DesiredRecords@)
    Authority=@Authority@
     Check if zone exists
    echo "listzones" | zrsh | awk '{ print $2 }' | grep '^@EscapedZone@\.$' && ZoneExists=1
     If zone didn't exist, create it
    if [ $ZoneExists -eq 0 ]; then
       Create Zone File Defaults
      ISODate=`date +%Y%m%d`
    cat << EOF > ${ZoneFile}
      \$ORIGIN .
      \$TTL 500        ; 8 minutes 20 seconds
      ${Zone}.            IN SOA  ${Authority}. hostmaster.${Zone}. (
      ${ISODate}01 ; serial (YYYYMMDDVV)
                                      10800      ; refresh (3 hours)
                                      3600       ; retry (1 hour)
                                      604800     ; expire (1 week)
                                      60         ; minimum (1 minute)
      \$TTL 0  ; 0 seconds
                              NS      ${Authority}.
      \$TTL 3600       ; 1 hour
      \$ORIGIN ${Zone}.
      \$TTL 0  ; 0 seconds
    EOF
      echo "addZoneFile external @Zone@. master db.external.@Zone@. \"${ZoneFile}\"" | zrsh
      rm -f ${ZoneFile}
    fi
     Strip existing static records
    echo "displayzone @Zone@." | zrsh | grep '@RecordType@' | awk '{ cmd=sprintf("echo ''delrr external %s %s %s %s %s %s'' | zrsh ", $1, $1, $2, $4, $5, $6); system(cmd) }'
     Set desired static records
    for i in "${DesiredRecords[@]}"; do
      echo "addrr $i" | zrsh;
    done
  • Does anyone knows how to create a slave zone with zrsh ??
    I have a hundreds of zone to create on my GTM as slave and I cannot resign myself to use the webUI !
    Except this article, I found no other example of use of zrsh.
  • jba3126's avatar
    jba3126
    It baffles me to this day how this has not been accomplished for going on 12+ years now. Especially with Automation. It is painful to use the iControl SOAP interface. It works, but we know it is being deprecated and what then ... SSH again?
