BigBill_10036
Nov 19, 2013Converting from bagpipe to tmsh need help with conversion
Hello all,
I am needing a little help with a conversion process of changing some perl scripts that used bagpipe and now I need to use tmsh. The script I am converting is used to take a serve...
BigBill_10036
Nov 20, 2013So with a little testing on a development tool after hours, I found that the following tmsh command is the right command: tmsh modify ltm pool pool_name members modify { pool_member_name { session user-disabled state user-down }}
