karthick_85385's avatar
karthick_85385
13 years ago
Context path creation using IRULE
Hi All,
Need to access my URL from public network through a context path by using irule
F5 config details
VIP 10.10.5.5 port 443
Pool 10.10.10.1 port 8834
VIP Natted with one public IP and i need to access the URL as below
https:///yamss/
IRULE created in F5 and mapped to respective VIP
switch -glob [HTTP::uri] {
"/yamss*" -
nessus
pool pool_gen_yamss
I have done the above configuration but i cant able to access the application with the context path.
Please help me to resolve the issue.
Thanks in advance.
Regards,
karthick
  • make sure your routing is in place and accurate on the server side (if necessary). If the LTM is not the default gateway (or there is not a specific route for the client space back through the LTM) for the server, you will need to use snat automap or a snatpool on the virtual configuration. To validate your traffic flows, you can use the tcpdump utility in the command line interface.
  • hoolio's avatar
    hoolio
    Also, did you see any runtime TCL errors in /var/log/ltm? I'm not sure it would cause an error, but you had a - and { in your switch statement for the same case. Can you try this?
          "/yamss*" {
             nessus
             pool pool_gen_yamss
    Aaron
