ConfigSync not work -LAB
Hi
I am studying F5 and I downloaded this version from F5 Website "BIGIP-11.3.0.39.0-scsi"--BIG-IP Local Traffic Manager Virtual Edition Trial;
But I am facing issue to configure ConfigSync, and I do not know if this issue related to license do not have this feature or technical issue, I need your help, plz
when i try to configure HA, one of BIG-IP display at top corner on left close to logo as Green disconnected and another shown red disconnected, I tried to ping between them, it is pingable
- DEJ_159363
Cirrus
Hello,
It appears HA is not supported with the trial version -
VE Trial edition restrictions and limitations
- BIG-IP High Availability (HA) feature is not supported.
- Nath
But the link you've provided is for 11.3. - lanco1_253964
Hello, thanks for ur inputs, - DEJ_159363
Cirrus
Nathaneil -- Not sure what you mean. The page I linked is the guide for BIG-IP Virtual Edition 11.3.0 Trial available via https://www.f5.com/trial/secure/documentation.php?product=ltmve. The version the OP has discussed is one of the available trial version downloads available from the same page. This specific file is compatible with VMware ESX/i. If I'm missing something please elaborate.
- DEJ
Hello,
- Nath
- Nath
Tried to use version 12 or 11.6 then configure HA mode - Ecesureshkumar
Hi, is this issue resolved ? is that HA interface configured PORT LOCK DOWN with ALLOW DEFAULT
