zafer's avatar
zafer
16 years ago
Client Certificate validation problem with Firefox
Hello
im doning Client Certificate validation with iRule, everthing works properly with internet explorer but when we use Firefox we see multiple times Client certificate request from bigip
here is the similar problem informatin
http://hexale.blogspot.com/2008/12/firefox-and-client-certificates-privacy.html
how can i solve this problem
regards
zafer
  • hoolio's avatar
    hoolio
    Hi Zafer,
    Can you try testing by setting 'SSL::authenticate once' instead of 'SSL::authenticate always'?
    Thanks,
    Aaron
  • zafer's avatar
    zafer
    Hello Aaron
    here is my rule,
    i have problem with Firefox (older versions) it asks multiple time Client Certificate. i dont have problem with IE and latest Firefox release
    i tried this rule i added in this rule (SSL::authenticate once)
    another problem sometimes client wait on the page and then click some where but it matches Elseif section in iRule (it does not have client certificate) we have this problem randomly
    note: server session timeout value is 10 minutes
    what can be problem
    regards
    zafer
    when CLIENTSSL_CLIENTCERT {
    set time to maintain session data (in seconds)
    set session_timeout 7200
    set ssl_cert [SSL::cert 0]
    set ssl_errstr [X509::verify_cert_error_string [SSL::verify_result]]
    set ssl_stuff [list $ssl_cert $ssl_errstr]
    session add ssl [SSL::sessionid] $ssl_stuff $session_timeout
    set ssl_stuff2 [session lookup ssl [SSL::sessionid]]
    set ssl_cert2 [lindex $ssl_stuff2 0]
    set ssl_errstr2 [lindex $ssl_stuff2 1]
    if { $ssl_errstr2 eq "ok" } {
    HTTP::header insert SSLClientCertStatus $ssl_errstr2
    HTTP::header insert SSLClientCertSN [X509::serial_number $ssl_cert2]
    HTTP::header insert SSLClientCertb64 [b64encode $ssl_cert2]
    HTTP::header insert ClientSSL_Serial_F5 [X509::serial_number $ssl_cert2]
    HTTP::header insert ClientSSL_Issuer_F5 [X509::issuer $ssl_cert2]
    HTTP::header insert ClientSSL_subject_F5 [X509::subject $ssl_cert2]
    HTTP::header insert ClientSSL_not_valid_after_F5 [X509::not_valid_after $ssl_cert2]
    HTTP::header insert ClientSSL_not_valid_before_F5 [X509::not_valid_before $ssl_cert2]
    } elseif { $ssl_errstr2 eq "" } {
    SSL::renegotiate
    HTTP::redirect "http://domain.com/nocert.asp"
    log local0. "client: [IP::remote_addr]:[TCP::remote_port] Empty certificate request"
    send HTTP 302 redirect to an error page
    HTTP::redirect "http://domain.com/error.asp"
    log local0. "client: [IP::remote_addr]:[TCP::remote_port] Not valid or not empty request"
  • zafer's avatar
    zafer
    Hello Aaron
    here is my rule,
    what can be problem
    regards
    zafer
  • zafer's avatar
    zafer
    please discard first message, i forget in Rule
    zafer
  • hoolio's avatar
    hoolio
    Hi Zafer,
    Can you check your other post for a suggested update to the iRule ()? If you have any problems, please include details of what iRule, browser and client cert you're testing with.
    Thanks,
    Aaron
