Cli command for verification
Hi all, i'm new to F5. Planning an installation of F5 2400 viprion customer ask a checklist to verify power, fan, memory, software\hardware version\platform and interfaces ( type and state ). All this done by command line with example output. Can someone indicate me the right command sequence to give to achieve this ? Last software release.
Thanks all smaikol
- StephanManthey
Nacreous
The following commands will be your friends:
tmsh show sys hardware tmsh show sys cluster tmsh show net interface tmsh show sys software tmsh show sys versionThe output may vary and I don´t have a C2400 in my lab ...
- smaikol_134638
Thanks Stephan,
gonna look if i find some output example related, trying to check if i can get a test 2400.
cheers smaikol
- smaikol_134638
Stephan,
if it's possible , how to verify with tmsh command an f5 2100 blade used with a viprion 2400 ?
Thanks again a lot smaikol
- StephanManthey
Nacreous
Hi smaikol,
you will find the the specific terms for the chassis and blade in the hardware related output:A109 - VIPRION B2100 Blade
F100 - VIPRION C2400 ChassisThanks, Stephan
- smaikol_134638
Thanks Stephan,
may i ask you if BIG-IP commands are the same or is it a different command line ? In case which are the pair commands to verify the platform at power on?
Thanks really a lot smaikol
- StephanManthey
Nacreous
These commands work on all TMOS v10/v11 platforms.
The 'cluster' command can be used on VIPRIONs only.
Very likely the 'hardware' and 'interface' commands are most interesting for H/W and layer 1/2 related information:
tmsh show sys hardware tmsh show net interfaceEspecially regarding the hardware you can expect a lot of platform specific data output. You may use grep, cut, awk to filter the relevant data.
Sorry for not being able to provide sample output.
- smaikol_134638
Thanks Stephan,
Not a problem for the output i'm searching around. Thanks. smaikol
- smaikol_134638
One more question Stephan, sorry to abuse of your kindness, i cannot find any administration guide of the F5 viprion, for the GUI, can you point me in the right direction ?
Thanks, smaikol
- StephanManthey
Nacreous
Hi, there is no specific WebUI or CLI for the VIPRION. TMOS is always the same on all platforms. Of course you will only find some platform specific enhancements, i.e. 'Mirroring' on systems with RAID hard drives and i.e. 'Cluster' settings for VIPRION platforms. But that´s it. Everything else is the same.
Have a look at the VIPRION platform guides (available on Ask F5) please for a description of clustering.
Personally I would recommend to involve a trained engineer for a VIPRION deployment, especially if you are going to run it with multiple blades.
