MarkMackie_5812's avatar
MarkMackie_5812
14 years ago
changing outgiong SNAT based on Requesting IP
Right now I have the following:
Any UDP 500 requests get snatted to let say 10.10.12.1 (public ip) so any UDP 500 traffic goes out as an IP i want the request to come back on.
I have another VS that listens on that IP 10.10.12.1 and forwards it to the firewall behind it.
The problem I am having is using a VPN client from the inside isn't working because I think it gets sent to the firewall and not to the requesting computer on the inside. What I would like to do is:
If the UDP 500 request is coming from internal subnet of 192.168.1.0/24 then snat it to 11.11.11.1
how can I do that with an irule
  • Hoolio answered a similar post on iRules and SNAT'ing, perhaps it will get you going in the right direction:
    https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/61990/showtab/groupforums/Default.aspx
    when CLIENT_ACCEPTED {
    Check if client is in 192.168.1.0/24 subnet
    if {[IP::addr [IP::client_addr] equals 192.168.1.0/24]}{
    Use the snatpool
    snatpool snatpool_11.11.11.1
