Stephane_Deshai's avatar
Stephane_Deshai
Sep 11, 2012
Change IP in a SIP INVITE
I'm managed to change the IP in a SIP INVITE with this iRule :
when SIP_REQUEST {
if {[SIP::method] == "INVITE" && [SIP::uri] contains "10.215.186.38" }{
eval [LB::select]
set ipSelected [string map "10.215.186.38 [LB::server addr]" [SIP::uri]]
set ipSelected2 [string map {"%10" ""} [SIP::uri]]
But the problem that I have is that my LB::server addr is in a specific route domain and the IP finish with %10 so I have to remove the %10 in the SIP::uri. ex.: sip:[email protected]%10:5060.
Can someone hep me ?
  • hoolio's avatar
    hoolio
    Hi Stephane,
    You can use getfield to split off the % and get just the IP:
    set ip [getfield "1.1.1.1%10" "%" 1]
    Aaron
  • Thank you ! but something doesnt work here the change I made .. :
    when SIP_REQUEST {
    eval [LB::select]
    set ip [getfield $ipSelected "%10" 1][SIP::uri]
    I'm not sure about the last [SIP::uri]
    Also, is it possible that each time a make a change in an iRule that I have remove the iRule from the VS and put it back ?
  • hoolio's avatar
    hoolio
    No, but the iRule won't take effect for existing connections (by design). You could manually clear the connection for your client using 'tmsh delete sys conn cs-client-addr 1.1.1.1'
    If you're trying to replace the IP%RD with the server address in the SIP URI you could try this:
    when SIP_REQUEST {
       if {[SIP::method] eq "INVITE" && [SIP::uri] contains "10.215.186.38" }{
           Force a pool member selection
          eval [LB::select]
           Rewrite the destination to the server IP
           Ex SIP URI: sip:[email protected]%10:5060
          SIP::uri [string map "10.215.184.71%10 [LB::server addr]" [SIP::uri]]
    Aaron
