raweel's avatar
raweel
Dec 17, 2022
Solved
Can I disable automatically power on?
Howdy guys!
I'm using the i850.
I want to disable the function of auto-power on.
If can, could you please tell me how to configure?
Thanks in advance!
  • Hi Raweel,
    after performing a system Halt via LCD, it should stay in this position until you power it up manually via LCD. This should work even if you unplug the power cord...
    An unexpected power loss without performing a regular system halt will perform an automatic powerup.
    Cheers, Kai
  • Hi Raweel,
    Cheers, Kai
    • raweel's avatar
      raweel
      Hi Kai_Wilke,
      Thanks for your prompt message!
      Got it, I try your method in my environment.
      Best regards, raweel
