BNA and LTM 4200v TFTP not working.
I am running BNA for configuration backup. BNA logs in, TFTPs the files back, and saves them. If we needed to restore the LTM, I can have the LTM pull the config file back down. We have this working with the 3900 platform just fine. We have recently switched to the 4200v and now can not get the TFTP to work. We have the same config as far as the port lockdown. We are working with Support but I was wondering if anyone had some thoughts while waiting to get the answer.
- What_Lies_Bene1
Are there are specific error messages or more details you can share? Is there a difference in the TMOS versions being used on each platform?
BTW, TFTP is somewhat insecure, does BNA support SCP or SFTP at all?
- What_Lies_Bene1
Did your laptop have a connection/route back to the device or a firewall package enabled? Do you see the same behaviour when using BNA and is the file pushed in the same way (i.e. F5 is the client and sends to the server).
From what you posted, it doesn't look like your laptop responded to the WRQ request with an TFTP ACK.
It's odd that your laptop reports a forcible closure as this is UDP and therefore there is no such thing!
- Messe
Yes, my laptop has a route back to the device.textC:\Users\sbmesse>ping 10.171.58.6
Pinging 10.171.58.6 with 32 bytes of data: Reply from 10.171.58.6: bytes=32 time=169ms TTL=247 Reply from 10.171.58.6: bytes=32 time=169ms TTL=247
Ping statistics for 10.171.58.6: Packets: Sent = 2, Received = 2, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 169ms, Maximum = 169ms, Average = 169ms
The file is pushed the same way. F5 is the client and BNA is the server.
I get the same thing when I try to send it to BNA. THe LTM can ping the BNA server.
[root@LB-JP-SRV1-1:Active:In Sync] config tftp 161.173.59.48 tftp> verbose Verbose mode on. tftp> trace Packet tracing on. tftp> put /var/local/scf/agent-160249.tmp agent-160249.tmp putting /var/local/scf/agent-160249.tmp to 161.173.59.48:agent-160249.tmp [netascii] sent WRQ sent WRQ sent WRQ sent WRQ sent WRQ Transfer timed out.
tftp> quit [root@LB-JP-SRV1-1:Active:In Sync] config ping 161.173.59.48 PING 161.173.59.48 (161.173.59.48) 56(84) bytes of data. 64 bytes from 161.173.59.48: icmp_seq=1 ttl=55 time=168 ms 64 bytes from 161.173.59.48: icmp_seq=2 ttl=55 time=168 ms 64 bytes from 161.173.59.48: icmp_seq=3 ttl=55 time=168 ms 64 bytes from 161.173.59.48: icmp_seq=4 ttl=55 time=168 ms ^C --- 161.173.59.48 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 2999ms rtt min/avg/max/mdev = 168.228/168.717/168.922/0.405 ms
- What_Lies_Bene1
Is there a firewall between the F5 device and the BNA server or your laptop?
- Messe
Here is the tcpdump from the 4200 [root@LB-JP-SRV1-1:Active:In Sync] config tcpdump -nni 0.0 host 161.173.59.48 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 15:59:02.715107 IP 10.171.58.6.46281 > 161.173.59.48.69: 28 WRQ "agent-160249.tmp" netascii 15:59:02.901345 IP 161.173.59.48.39795 > 10.171.58.6.46281: UDP, length 19 15:59:02.902001 IP 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 46281 unreachable, length 36 15:59:07.715263 IP 10.171.58.6.46281 > 161.173.59.48.69: 28 WRQ "agent-160249.tmp" netascii 15:59:07.904240 IP 161.173.59.48.39135 > 10.171.58.6.46281: UDP, length 19 15:59:07.904962 IP 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 46281 unreachable, length 36 15:59:12.715289 IP 10.171.58.6.46281 > 161.173.59.48.69: 28 WRQ "agent-160249.tmp" netascii 15:59:12.885430 IP 161.173.59.48.59497 > 10.171.58.6.46281: UDP, length 19 15:59:12.886446 IP 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 46281 unreachable, length 36 15:59:17.715327 IP 10.171.58.6.46281 > 161.173.59.48.69: 28 WRQ "agent-160249.tmp" netascii 15:59:17.885188 IP 161.173.59.48.43585 > 10.171.58.6.46281: UDP, length 19 15:59:17.886054 IP 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 46281 unreachable, length 36 15:59:22.715444 IP 10.171.58.6.46281 > 161.173.59.48.69: 28 WRQ "agent-160249.tmp" netascii 15:59:22.884091 IP 161.173.59.48.38007 > 10.171.58.6.46281: UDP, length 19 15:59:22.885389 IP 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 46281 unreachable, length 36 Here is the tcpdump from the 3900 [root@LB-EDC-SRV2-1:Active:In Sync] config tcpdump -nni 0.0 host 10.98.11.135 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 17:13:05.220018 IP 172.17.40.6.42927 > 10.98.11.135.69: 28 WRQ "agent-579614.tmp" netascii 17:13:05.265878 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.266956 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 17:13:05.272177 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.272878 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 17:13:05.277888 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.278880 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 17:13:05.283374 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.283887 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 17:13:05.289118 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.289865 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 17:13:05.294381 IP 10.98.11.135.62508 > 172.17.40.6.42927: UDP, length 4 17:13:05.294843 IP 172.17.40.6.42927 > 10.98.11.135.62508: UDP, length 516 So it looks to me that the 4200 is saying that the port is not available after he said that was the port he was going to use.- What_Lies_Bene1
Thanks but unless you can format the output I'm not going to be able to read it I'm afraid.If you select it all and click the 'button' with the grey strip on it's left that should do it. Cheers - Messe
Sorry. I have fixed it. I am new to devcentral. I was wondering how to make it look correct. Thanks for the tip.
- What_Lies_Bene1
Indeed it does. Does the traffic route out of the management interface or a TMM interface? Any chance you have AFM installed?
- What_Lies_Bene1
OK, interesting. So, a few more things;
1) Can you run the tcpdump on the 4200 device adding -vv (that's v twice, not w) so it provides more verbose output
2) can you try using netcat to test too, I'm not sure from memory if it's installed but try nc, ncat or netcat at the CLI
3) can you post the port lockdown settings for the self ip in question please and finally
4) can you try adding a specific route in LTM for the BNA host or the subnet it's on please.
- Messe
Here is the tcpdump -vv [root@LB-JP-SRV1-1:Active:In Sync] config tcpdump -vv -nni 0.0 host 161.173.59.48 tcpdump: listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 09:35:15.860124 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17891 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:35:16.039529 IP (tos 0x0, ttl 55, id 53558, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.35817 > 10.171.58.6.17891: [udp sum ok] UDP, length 19 09:35:16.039904 IP (tos 0x0, ttl 255, id 6763, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17891 unreachable, length 36 IP (tos 0x0, ttl 55, id 53558, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.35817 > 10.171.58.6.17891: UDP, length 19 09:35:20.860201 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17891 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:35:21.028248 IP (tos 0x0, ttl 55, id 53559, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.41953 > 10.171.58.6.17891: [udp sum ok] UDP, length 19 09:35:21.029110 IP (tos 0x0, ttl 255, id 23118, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17891 unreachable, length 36 IP (tos 0x0, ttl 55, id 53559, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.41953 > 10.171.58.6.17891: UDP, length 19 09:35:25.860243 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17891 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:35:26.028611 IP (tos 0x0, ttl 55, id 53560, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.51623 > 10.171.58.6.17891: [udp sum ok] UDP, length 19 09:35:26.029099 IP (tos 0x0, ttl 255, id 63946, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17891 unreachable, length 36 IP (tos 0x0, ttl 55, id 53560, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.51623 > 10.171.58.6.17891: UDP, length 19 09:35:30.860316 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17891 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:35:31.029024 IP (tos 0x0, ttl 55, id 53561, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.44508 > 10.171.58.6.17891: [udp sum ok] UDP, length 19 09:35:31.030415 IP (tos 0x0, ttl 255, id 56690, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17891 unreachable, length 36 IP (tos 0x0, ttl 55, id 53561, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.44508 > 10.171.58.6.17891: UDP, length 19 09:35:35.860369 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17891 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:35:36.028675 IP (tos 0x0, ttl 55, id 53562, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.35585 > 10.171.58.6.17891: [udp sum ok] UDP, length 19 09:35:36.029332 IP (tos 0x0, ttl 255, id 64237, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17891 unreachable, length 36 IP (tos 0x0, ttl 55, id 53562, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.35585 > 10.171.58.6.17891: UDP, length 19 Here is the tcpdump after the route added, 09:50:43.681132 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17552 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:50:43.890132 IP (tos 0x0, ttl 55, id 53563, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.47085 > 10.171.58.6.17552: [udp sum ok] UDP, length 19 09:50:43.891040 IP (tos 0x0, ttl 255, id 28279, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17552 unreachable, length 36 IP (tos 0x0, ttl 55, id 53563, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.47085 > 10.171.58.6.17552: UDP, length 19 09:50:48.681209 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17552 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:50:48.851267 IP (tos 0x0, ttl 55, id 53564, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.49750 > 10.171.58.6.17552: [udp sum ok] UDP, length 19 09:50:48.852292 IP (tos 0x0, ttl 255, id 59943, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17552 unreachable, length 36 IP (tos 0x0, ttl 55, id 53564, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.49750 > 10.171.58.6.17552: UDP, length 19 09:50:53.681291 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17552 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:50:53.849545 IP (tos 0x0, ttl 55, id 53565, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.49688 > 10.171.58.6.17552: [udp sum ok] UDP, length 19 09:50:53.850043 IP (tos 0x0, ttl 255, id 20784, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17552 unreachable, length 36 IP (tos 0x0, ttl 55, id 53565, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.49688 > 10.171.58.6.17552: UDP, length 19 09:50:58.681309 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17552 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:50:58.849741 IP (tos 0x0, ttl 55, id 53566, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.38342 > 10.171.58.6.17552: [udp sum ok] UDP, length 19 09:50:58.850212 IP (tos 0x0, ttl 255, id 59996, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17552 unreachable, length 36 IP (tos 0x0, ttl 55, id 53566, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.38342 > 10.171.58.6.17552: UDP, length 19 09:51:03.681392 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto: UDP (17), length: 56) 10.171.58.6.17552 > 161.173.59.48.69: [udp sum ok] 28 WRQ "agent-160249.tmp" netascii 09:51:03.849714 IP (tos 0x0, ttl 55, id 53567, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.36877 > 10.171.58.6.17552: [udp sum ok] UDP, length 19 09:51:03.850384 IP (tos 0x0, ttl 255, id 20822, offset 0, flags [DF], proto: ICMP (1), length: 56) 10.171.58.6 > 161.173.59.48: ICMP 10.171.58.6 udp port 17552 unreachable, length 36 IP (tos 0x0, ttl 55, id 53567, offset 0, flags [none], proto: UDP (17), length: 47) 161.173.59.48.36877 > 10.171.58.6.17552: UDP, length 19 As far as port lockdown, I have it set to Allow All on both the floater and the self-IP. I am still working on the netcat, but I wanted to the post the other information. - Messe
We are able to copy a small file across port 7000. the real backup file we get about 10 lines and then a write error. LTM netcat [root@LB-JP-SRV1-1:Active:In Sync] config cat /var/local/scf/lb-jp-srv1-1 | nc -u 161.173.59.48 7000 nc: Write error: Connection refused Server netcat [root@bbna-agent-e01 tftpboot] nc -l -u -w 3600 7000 cli admin-partitions { update-partition Common } cm cert /Common/dtca-bundle.crt { cache-path /config/filestore/files_d/Common_d/trust_certificate_d/:Common:dtca-bundle.crt_14 checksum SHA1:2201:3e50cd3f97366f326e394f995c35a4df5dc16721 revision 14 } cm cert /Common/dtca.crt { cache-path /config/filestore/files_d/Common_d/trust_certificate_d/:Common:dtca.crt_8 checksum SHA1:1265:f6e270fe7d2fb02c3462969f5a07150972fd51a3 revision 8 } cm cert /Common/dtdi.crt { cache-path /config/filestore/files_d/Common_d/trust_certificate_d/:Common:dtdi.crt_8 checksum SHA1:1261:c52e425d5bf32b30f12654d2bdc104fa5941f852 revision 8 } cm device /Common/LB-JP-SRV1-1.homeoffice.jp.wal-mart.com { active-modules { "GTM-DNS, RL, LO, BIG-IP|QZSFXZE-GARKFMS|DNS Rate Fallback, 50|GTM Rate Fallback, 8|DNS Licensed Objects, 0|GTM Rate, 8|DNS Rate Limit, 50 QPS|GTM Licensed Objects, 0" "LTM, Base, 4200V|HAGNHPH-CBFMNTM|SSL, Max TPS|Max Compression|Application Acceleration Manager, Core|IPV6 Gateway|- What_Lies_Bene1
You sure what you've posted is correct? Lot's of config there! Why port 7000? - Messe
So with netcat we could not use port 69 because BNA was already using it so we just picked a random port. Also it was in the example we saw on how to use netcat. Also looking on the amount of data that was able to be sent across, it was 1024 characters and then we get the error.
- Messe
Here is the update we have received from support.
I have spoken with the escalation engineer and at this point we have confirmed that the issue with TFTP connectivity exists in v11.2.x but does not in v11.4.1 so we are sifting through any known issues that may cause this intermittent behavior.
From the tcpdumps, we see that the initial RRQ(get) / WRQ (put) communication on port 69 is fine. It's the data flow over the ephemeral port that isn't recognized by BIG-IP causing an ICMP port unreachable response.
