BigIP Edge Client download
Hello,
Using a BigIP 3900 running 12.1.2. I am unable to download the BIGIPEdgeClient.exe from the management WebUI.
Going to Access Policy/Secure Connectivity, then selecting my connectivity profile, the Customize Package becomes available (clickable). As soon as I click on it (or choose Windows/Mac if I click on the down arrow), the button becomes greyed out, and nothing happens. No popup window, no download, nothing...
Do you have any suggestions ? Because I am currently stuck with clients having to install the plugin themselves during first connection.
- youssef1
Cumulonimbus
Did you try to use another Browser? (you can also try to download the client from your standalone if you have a cluster)
Otherwise you can try to download it using tab "About" near tab "Help" in the top left.
Then you have --> Downloads --> BIG-IP Edge Client™ Components
Regars
- cd
Cirrus
So I actually found the solution... Very weird indeed.
My custom connectivity profile was created on a dedicated partition, while being based on the parent profile /Common/connectivity.
If I create an exacte same custom connectivity profile in the Common partition, I get the popup to download the client.
