Agruet_315245's avatar
Agruet_315245
Apr 03, 2017
BIGIP APM and Management Interface and/or UI.
Dear F5 experts,
I recently settled my first VPN client access through APM. I Created a profile, assigned a Policy based on a local user DB, settled the network property and everything is working like a charm.
However, there is something i would like to see working, even i know this is not a good practice, How, you guys, access to the management UI through a VPN client ? I understand TMM is separated of Management console port and these Vlans are not visible them each other.
Since our HA pair of BIGIP VE are hosted on a cloud platform i don't see how i can take advantage of the VPN Client access to reach the BIGIP Management IP and play with the Configuration Utility.
Maybe there is a secret trick, so please share your insights.
  • Dear,
    Copied from the below devcentral article where Kevin Stewart answered it :
    https://devcentral.f5.com/questions/cant-access-to-management-interface-after-vpn-using-apm-established
    "This is actually a well-intentioned security feature, but you can get around it with the following trick:
    Create a simple LTM virtual server - you can bind this to the VPN connectivity profile "VLAN" or to an internal VLAN (do NOT bind this to an external VLAN) Apply a simple client SSL profile to the VIP Apply a simple server SSL profile to the VIP Apply the following iRule to the VIP:
    when CLIENT_ACCEPTED {
    node 127.0.0.1 443
    Depending on platform version you may need to use an internal VLAN self-IP instead of 127.0.0.1."
    Hope it helps..
