amolari's avatar
amolari
Jul 08, 2026
APM OIDC debug logging is somehow verbose but not where it should - RFE
While I was configuring and testing an APM Access policy for an OIDC integration with Entra ID, I was seeing some backchannel errors logged (debug level) some HTTP error 400.
The whole logging is quite verbose, but here, not very useful:
OAuth Client: failed for server '/Common/entraid_test' using 'authorization_code' grant type (client_id=xxxxxxxxxxxxxx), error: HTTP error 400,
Session variable 'session.oauth.client./Common/entra_front_act_oauth_client_ag.errMsg' set to 'HTTP error 400, '
Session variable 'session.oauth.client./Common/entraid_test.errMsg' set to 'HTTP error 400, '
Session variable 'session.oauth.client.last.errMsg' set to 'HTTP error 400, '
So, tcpdump was required to see what exactly the error was in the returned JSON payload from Entra ID.
I've got a new RFE from F5 support =>
(Bug alias 2229965) [RFE] Add extra verbosity for the debug-level logging for OIDC backchannel connection
Don't hesitate to open a support case to get it bound to that RFE, the more we are the higher priority will be assigned to implement it (hopefully). đŸ˜€
Alexandre
    • amolari's avatar
      amolari
      Hello Kostas,
      it's not a recent case, I don't have the config handy anymore. It was a complicated case with Entra ID, issues with the Tenant that was initially not working as expected (Microsoft support involved etc..)
      In the 400 json payload some helpful information:
      "error": "invalid_request"
      "error_description": "AADSTS50146: This application is required to be configured with an application-specific signing key. It is either not configured with one, or the key has expired or is not yet valid. Trace ID: db2a04a0-7d54-4d37
      No issue using tcpdump, but it takes longer time in some customer environments until one can display the capture in wireshark...
