Tony2020's avatar
Tony2020
May 24, 2017
Better way to match different URI based on XFF and different data group with IP
Hi All,
I was wondering if anyone can point out or suggest a better or more effcient way to put together the two logic together in this code.
Data group:
  1. Data group with IP 1.1.1.1/32 & 1.1.1.2/32 & 5.5.5.0/24 called "DG-XFF-EXTERNAL-ALLOWED-IP"
  2. Data group with IP 2.2.2.1/32 and 2.2.2.2/32 called "DG-XFF-INTERNAL-ALLOWED-IP"
Requirement:
  1. if the external users IP is in "DG-XFF-EXTERNAL-ALLOWED-IP" and they go to URI "/externalURI" they are allowed in based on XFF IP matching, otherwise they will be rejected
  2. if users IP is in "DG-XFF-INTERNAL-ALLOWED-IP" and they go to URI "/internalURI" they are allowed in based on XFF IP matching, otherwise the will be rejected
irule
set CHECK_IP [getfield [HTTP::header values X-Forwarded-For] " " 1]
      switch -glob [HTTP::uri] {
             “/externalURI“ {
           if { ! ([class match $CHECK_IP eq DG-XFF-EXTERNAL-ALLOWED-IP) } {
             reject
             “/InternalURI“ {
           if { ! ([class match $CHECK_IP eq DG-XFF-INTERNAL-ALLOWED-IP) } {
             reject
Thank you!
  • JG's avatar
    JG
    Try this modified one:
        foreach CHECK_IP [split [string map [list " " ""] [HTTP::header "X-Forwarded-For"]] ","] {
            switch -glob [string tolower [HTTP::path]] {
                "/externaluri" {
                    if { ! ([class match $CHECK_IP eq DG-XFF-EXTERNAL-ALLOWED-IP]) } {
                        reject
                "/internaluri" {
                    if { ! ([class match $CHECK_IP eq DG-XFF-INTERNAL-ALLOWED-IP]) } {
                        reject
                default {
