tacobell_14395
Aug 23, 2011Basic question on Irules
Basic question, besides removing the string how can i basically add a REMARK before a string....i am trying to simply not log but want to remark ( or do not use ) the line that starts with log...make sense???
log local0. "client IP is [IP::client_addr]"
if { not [matchclass [IP::client_addr] eq address_datagroup] } {
log local0. "[IP::client_addr] is accepted
- hoolio
You can comment out a line using a hash ():when HTTP_REQUEST { log local0. "client IP is [IP::client_addr]" if { not [matchclass [IP::client_addr] eq address_datagroup] } { log local0. "[IP::client_addr] is accepted } }
Aaron - Colin_Walker_12Historic F5 AccountAlso worth noting: Commented lines (lines beginning with a hash as Aaron mentioned above) are not compiled into your byte code that is interpreted by TMM. This means that comments have no effect on overhead of your iRule.
The more you know. ;)
Colin
