davidy2001's avatar
Oct 29, 2022
Authentication issue when setting up F5
Hi When I setup a new F5, I got anthentication issue. Please see below. After I was required to change password, I created new password, but  I got authentication issue. I do not know what is wrong? Anyone can provide suggestion? Thank you
BIG-IP 15.1.0 Build 0.0.31
Kernel 3.10.0-862.14.4.el7.ve.x86_64 on an x86_64
localhost login: root
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Authentication failure
  • davidy2001you are receiving the "Authentication failure" because you have to enter the default password again and after that it will prompt you for the new password. Notice that it says "(current)" next to "UNIX password:" meaning the password that you entered when you first logged in. UNIX does this as a safe guard essentially so that if for some reason a user was left logged in you couldn't just change the password to a new one without knowing what the current password is.
