cookiemonster's avatar
cookiemonster
Mar 06, 2020
AS3 Pool Monitor Always Being Set to HTTP
I am working with the declaration below. When I post the declaration to the F5 no matter what I set as the pool monitor in the declaration the F5 sets the monitor to the preloaded http monitor. As a test I tried to remove the http monitor manually and select a different monitor. After clicking update the F5 sets the monitor back to http. Am i missing something?
Declaration:
    "class": "AS3",
    "declaration": {
        "class": "ADC",
        "schemaVersion": "3.12.0",
        "id": "0",
        "shortlived": {
            "class": "Tenant",
            "myhui1076_test": {
                "class": "Application",
                "template": "default",
                "myhui1076_test": {
                    "class": "Service_HTTPS",
                    "snat": "self",
                    "serverTLS": {
                        "bigip": "/Common/digistar.spectrum-health.org"
                    "virtualAddresses": [
                        "9.9.9.9"
                    "pool": "myhui1076_test_pool"
                "myhui1076_test_pool": {
                    "class": "Pool",
                    "monitors": [{
                        "use": "/Common/http_monitor"
                    "loadBalancingMode": "least-connections-member",
                    "members": [
                            "adminState": "enable",
                            "servicePort": 80,
                            "serverAddresses": [
                                "10.10.10.10"
                            "hostname": "test_server"
F5 Config:
