Wes_Emerson_868's avatar
Wes_Emerson_868
Mar 11, 2009
Application SSL Offloading Issues
Half of the problem is that I don't really know what to ask for, so let me explain my issue (grab your favorite beverage).
I am trying to SSL offload an application called Moodle, and I can get the login page to work beautifully, the problem is that the application has a ton of links that still redirect back to port 80 using the original server name.
I tried to write an Irule that would change the name of the server and port, but I am new to irules and it didn't go over too well. Can somebody with a bit more knowledge point me in the right direction, it would be greatly appreciated.
if { ! [HTTP::uri] starts_with "http://unsecure_host_name" } {
HTTP::uri "https://secure_host_name"
  • Perhaps you can use the stream profile
    Click here to see some information about using stream
    Hope this helps
    CB
  • I've played with the Streams examples that were referenced in the attached site, and it's some good stuff.
    However I still haven't found a way to rewrite the links that are embedded in the application. Would a mod_rewrite entry in the httpd.conf be a better solution then trying to rewrite the links on the fly with either a stream profile and an associated stream profile.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    It is possible to do it with the stream profile, but it's more efficient if the webserver does it.
