apm landing uri - bookmark issue for lambda users
This issue was always there with the Firepass (sol11580)... continuing with APM.
I have APM (portal mode) services that are accessed with landing URIs (https://abc.example.com/service1 ; https://abc.example.com/service2). Working fine. Now, when users want to bookmark that, it's not possible (except manually creating the bookmark) because of the redirect to https://abc.example.com/my.policy
Anyone has a workaround for that (and knows the RFE maybe)?
Thank you
Alex
- Michael_Jenkins
We had accomplished this when we used an external login page with some iRules that would add the initial URI to the query string as a parameter, and then if the user went to the page with a GET (instead of a POST, as the APM redirect would do), it would redirect to that uri (e.g. /service1), which our other iRule would grab that as the start uri.
In my attempt to rework the way we're using APM, I'm working on something similar for the built-in login page. In an iRule, you can use the
event to check for the redirect to /my.policy and update the uri from there so they could bookmark that page. So in theHTTP_RESPONSE_RELEASE
event, you could set a custom session variable for the start uri (i.e. session.custom.starturi),and then update the uri to include that on the login page.ACCESS_SESSION_STARTEDwhen HTTP_RESPONSE_RELEASE { switch [HTTP::status] { 301 - 302 { switch -glob [HTTP::header value Location] { "/my.policy" { switch [ACCESS::session data get session.custom.starturi] { "" - "/" { } default { HTTP::header replace Location "[HTTP::header value Location]?r=[URI::encode [ACCESS::session data get session.custom.starturi]]" } } } } } } }After that, you'll need to make sure the
event handler also handle uris with my.policy in them..ACCESS_SESSION_STARTEDwhen ACCESS_SESSION_STARTED { switch -glob [HTTP::uri] { "/?r=*" { If we have an empty path and an "r" parameter, we'll use that as the starturi The "r" param SHOULD be uri encoded set starturi [URI::decode [URI::query [HTTP::uri] "r"]] if { $starturi starts_with "/my.policy?r=" } { set starturi [URI::decode [string range $starturi 13 end]] } } default { set starturi [HTTP::uri] } } ACCESS::session data set session.custom.starturi $starturi }Then your iRule for handling starturis can deal with the redirect after the user is authenticated.
Hope this helps...
