After Load archive configuration F5 device Confuguration utility is restarting
Dears;
After i load previous configuration on my device
Sep 16 12:28:12 F5-LTM1 emerg load_config_files: "/usr/bin/tmsh -n -g load sys config partitions all" - failed. -- 01071769:3: Decryption of the field (secret) for object (/Common/system_auth_name1) failed. Unexpected Error: Loading configuration process failed.
when user insert username and Password ,Configuration usitlity is restarting and i can not login device using console give us wrong password
Thnaks
is it possible you tried to restore an UCS with the wrong password? or an UCS from another system by accident?
there are some SOLs that point to this error. what exactly was /Common/system_auth_name1 for type of config?
if you can't login anymore because of wrong password then password recovery is the only option:
http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13121.html
