Madhukara_33449's avatar
Madhukara_33449
Sep 25, 2017
Advice: Best practises for LTM+ASM
Im New to F5, need your help with the best practices for LTM+ASM HA configuration
Current Setup details:
Hardware: i5800 X 2 devices . Virtual Guests created on both the Physical devices. (Say VG1 on Device-1 and VG1 on Device-2) .
both the VG1 had been configured with LTM+ASM
Current HA setup
1) Have created HA group (Sync fail over method)
2) Specifically for ASM have created a Sync-only group with incremental update
Everything seems to be working fine.
Im worried about the HA implementation, Please suggest the best practices
  • Hey Madhukha,
    To setup the HA in a Active/Standby mode follow these steps :
    Note: You must perform this task locally on each device in the device group.
    • Specifying an IP for "config sync" & for "connection mirroring"
    "Device Management > Devices" => choose the local device
    From "Device Connectivity" menu, choose "ConfigSync" => F5 Networks recommends that you use the default value, which is the self IP address for the internal VLAN. This address must be a non-floating (static) self IP address and not a management IP address.
    From "Device Connectivity" menu, choose "Mirroring" => The recommended IP address is the self IP address for either VLAN HA or VLAN internal.
    • Establishing device trust
    "Device Management > Device Trust" then "Peer List" or "Subordinate List" Click Add
    • Creating a Sync-Failover device group
    "Device Management > Device Groups" click "Create"
    • Specifying IP for failover communication
    From "Device Connectivity" menu, choose "Failover Network" => Failover Unicast : preferably VLAN HA and the static management IP address
    Hope it helps
    Regards
