JD_Tomzak's avatar
JD_Tomzak
Icon for Cirrus rankCirrus
Sep 15, 2022
Solved
Irule advice?
Hello,
I'm seeking advice on using an Irule to drop a connection when a certain condition is met in the URI. fid= followed by non numeric charectors. fid=1234 would pass. fid=13d4 would drop. Thanks!
  • when HTTP_REQUEST {
        if { [string tolower [HTTP::query]] contains "fld" } {
            if { ![string is digit [URI::query [HTTP::uri] "fld"]] } {
                log local0. "invalid fld value, rejecting from [IP::client_addr]"
                reject
  • The following accounts for a POST request where the payload is URL encoded or XML:
        if { [HTTP::method] eq "POST" } {
            ## Trigger collection for up to 1MB of data
            if { [HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576 }{
                set content_length [HTTP::header "Content-Length"]
                set content_length 1048576
            ## Check if $content_length is not set to 0
            if { $content_length > 0 } {
                HTTP::collect $content_length
    when HTTP_REQUEST_DATA {
        set fld ""
        if { [HTTP::payload] contains "fld=" } {
            foreach x [split [HTTP::payload] "&"] {
                if { $x starts_with "fld=" } {
                    set fld [lindex [split $x "="] 1]
                    continue
        } elseif { [HTTP::payload] contains "<fld>" } {
            set fld [findstr [HTTP::payload] "<fld>" 5 "</fld>"]
        if { $fld ne "" } {
            if { ![string is digit $fld] } {
                HTTP::respond 400 content "Bad Request" "Content-Type" "text/html" "Connection" "close"
