Adding another F5 1600-LTM device for redundant porpose
Hi dears I had a F5 LTM-1600 device before and now i want to add another one for redundant porpose . Do every body know how i can take a configuration copy of the last one and mount it on the new one . Thanks in advance
- nathe
Cirrocumulus
If I understand you correctly, you want to add this new device as part of a Highly Available pair? If so then you don't need to copy the configuration. Just build the new 1600 device i.e. same image/hotfix as the existing one and the base networking (VLANs and Self IPs, mgmt etc.) and then create a new Device Group on the existing 1600. Add the secondary one and after the first configsync the configuration is copied across.
I've skipped over a few steps of course.
Hope this helps,
N
