El_Hassan_OUDRH's avatar
El_Hassan_OUDRH
Dec 10, 2015
ActiveSync don't work correctly for iphone mobile device
Hi, we have deployed last year an iapp exchange2010 that works well for all : owa, rpc, outlook anywhre, autodiscover and ActiveSync. now we have experiencing an issue with mobile device like iphone that is disconnected from ActiveSync somethimes without reason. (i see also that load balacing just for ActiveSync not works fine : 2 servers from 4 that don't receive match traffic like the other)
thank you for your help.
F5 version 11.4.1 HF9
see bellow the configuration :
ltm pool /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_as_pool { app-service /Common/EXchange_CAS.app/EXchange_CAS load-balancing-mode least-connections-member members { /Common/172.21.151.32:443 { address 172.21.151.32 } /Common/172.21.151.33:443 { address 172.21.151.33 app-service /Common/EXchange_CAS.app/EXchange_CAS } /Common/172.21.151.34:443 { address 172.21.151.34 } /Common/172.21.151.35:443 { address 172.21.151.35 } } monitor /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_https_monitor } ltm rule /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_persist_iRule { app-service /Common/EXchange_CAS.app/EXchange_CAS when HTTP_REQUEST { switch -glob [HTTP::path] {
    "/Microsoft-Server-ActiveSync*" {
                  Direct all ActiveSync clients to a common pool; use
                  HTTP cookie persistence
                 persist cookie
                  pool EXchange_CAS_combined_vs_as_pool
    "/rpc/rpcproxy.dll" {
                  Grab all requests for Outlook Anywhere; the following
                  checks assign correct persistence methods.
                 switch -glob [HTTP::header "User-Agent"] {
            "MSRPC" {
                          This User-Agent section matches most versions of
                          Outlook and Windows using Outlook Anywhere.
                          The OutlookSession cookie is new to Outlook 2010.
                         if { [HTTP::cookie exists "OutlookSession"] } {
                             persist uie [HTTP::cookie "OutlookSession"] 3600
                             persist uie [HTTP::header "Authorization"] 3600
            "*Microsoft Office*" {
                          This section matches some versions of
                          Outlook 2007 on Windows XP
                     default {
                          This section catches all other requests for
                          Outlook Anywhere, and sets a persistence method
                          that does not require the client to support
                          HTTP cookies
                         persist source_addr
                  Finally, this assigns the Outlook Anywhere pool and turns
                  off full HTTP parsing and compression. If the preceding
                  clients should be sent to separate pools, the pool statement
                  should be removed here, and a separate pool statement
                  placed in each of the preceding logic branches.
                  Other modules (APM, ASM, etc.) should be disabled here
                  as well, if active for other traffic though this virtual
                  server.
                  pool EXchange_CAS_combined_vs_oa_pool
                 CACHE::disable
                 HTTP::disable
                  COMPRESS::disable
    "/xml/autodiscover.aspx" {
                  Requests for Autodiscovery information. The selected pool
                  might be unique, or might be the same as e.g. your pool
                  for OWA or ActiveSync. In this example, we use the same
                  pool that receives ActiveSync traffic.
                 persist cookie
                  pool EXchange_CAS_combined_vs_ad_pool
             default {
                  This final section takes all traffic that has not
                  otherwise been accounted for and sends it to the
                  pool for Outlook Web App
                 persist cookie
                  pool EXchange_CAS_combined_vs_owa_pool
} ltm virtual /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_https_virtual { app-service /Common/EXchange_CAS.app/EXchange_CAS destination /Common/172.21.150.100:443 fallback-persistence /Common/EXchange_CAS.app/EXchange_CAS_source_address_persistence_profile ip-protocol tcp mask 255.255.255.255 persist { /Common/EXchange_CAS.app/EXchange_CAS_cookie_persistence_profile { default yes } } profiles { /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_caching_profile { } /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_clientssl { context clientside } /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_http_profile { } /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_oneconnect { } /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_serverssl { context serverside } /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_wan-optimized-compression_profile { } /Common/EXchange_CAS.app/EXchange_CAS_lan-optimized_tcp_profile { context serverside } /Common/EXchange_CAS.app/EXchange_CAS_wan-optimized_tcp_profile { context clientside } /Common/ntlm { } } rules { /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_owa_append_iRule /Common/EXchange_CAS.app/EXchange_CAS_combined_vs_persist_iRule /Common/Exchange_hsts_ltm } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled }
  • Recently AS was broken after upgrading to v11.6 in my clients implementation. After replacing the wan-optimized TCP profile by a plain TCP profile everything worked pretty well. Thanks
  • Guys, did you see this article? https://devcentral.f5.com/s/articles/stop-using-the-base-tcp-profile
  • Thank you. i have version 11.4.1 HF9. I don't found tcp-mobile-optimized, do you mean tcp-cell-optimized ?
    I found in this 2 profil that idle timeout is 300. do i have to change it to 1800 ? Thank you for your help
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      try without changes first i would say, then see what you can start changing with a positive effect.
  • that suggests not using it because it might not be the fastest solution, but it still works, if it helps against connection issues i don't see why not use it.
