kouriada_284551's avatar
kouriada_284551
Oct 03, 2018
Access-control-allow-origin changing according domains
Hi guys,
I would like to ask about your help.
I have to apply multiple Access-control-allow-origin for particular domains via irule
Description of the task is something like this:
When a client is going from domain A to source portal, the response should containt header Access-control-allow-origin domain A
When a client is going from domain B to source portal, the response should containt header Access-control-allow-origin domain B
etc
I need to see only header which contain particular domain * which I came from as a client
I was able to create only this:
when HTTP_RESPONSE {
if !{[HTTP::header exists "Access-Control-Allow-Origin"]} {
HTTP::header insert Access-Control-Allow-Origin "domain A"
HTTP::header insert Access-Control-Allow-Origin "domain B"
HTTP::header insert Access-Control-Allow-Origin "domain C"} }
but it doesnt do what I need and I am not able to create some conditional in that irule for particular domain and I see all CORS headers in one time via curl
I have been trying to do this via policy but, it seems to me that it doesnt work as well
I appreciate any help
AK
  • Hi
    How are you determining if a client originates from domainA or domainB - are they coming from a particular subnet for instance?
  • Hi,
    client will come from particular web page( where will be login page into source web page), so I can determine that according particular fqdn of that domainA or B
    I have been thinking that I could solve that like this: *.domainA, *.domainB and add those *.domains to Data groupe list and write something like this: if { ! [class match $act_uri contains allow_domains] and that the particular domain will be added to Access-Control-Allow-Origin *.domainA or *.domainB according client comes from
    or just write it down into couple simple irules, theoreticaly:
    *for .domainA:
    http:Request
    if http: host equal domainA
    than
    http response:
    http:header Access-Control-Allow-Origin domainA<>br
    *for .domainB:
    http:Request
    than
    http response:
    etc
    make it sense?
    I am not strong enough in writing of irules
    AK
  • Hello,
    you can use this share code ( Rory Hewitt 😞
    https://devcentral.f5.com/codeshare/cors-implementation
     Domains that are allowed to make cross-domain calls to example.com
    class allowed_origins {
        ".example.com"
        ".example2.com"
        ".goodpartner.com"
        unset -nocomplain cors_origin
        if { [class match [HTTP::header Origin] ends_with allowed_origins] } {
            if { ( [HTTP::method] equals "OPTIONS" ) and ( [HTTP::header exists "Access-Control-Request-Method"] ) } {
                 CORS preflight request - return response immediately
                HTTP::respond 200 "Access-Control-Allow-Origin" [HTTP::header "Origin"] \
                                  "Access-Control-Allow-Methods" [HTTP::header "Access-Control-Request-Method"] \
                                  "Access-Control-Allow-Headers" [HTTP::header "Access-Control-Request-Headers"] \
                                  "Access-Control-Max-Age" "86400" \
                                  "Vary" "Origin"
                 CORS GET/POST requests - set cors_origin variable
                set cors_origin [HTTP::header "Origin"]
         CORS GET/POST response - check cors_origin variable set in request
        if { [info exists cors_origin] } {
            HTTP::header insert "Access-Control-Allow-Origin" $cors_origin
            HTTP::header insert "Access-Control-Allow-Credentials" "true"
            HTTP::header insert "Vary" "Origin"
