zafer's avatar
zafer
Oct 22, 2008
.net persistence issue
Hello
here is my traffic flow
client --> ssl vpn-> Bigip vip-> webserver
the customer use .net application and i try to get aspsessionid and persist it with this code (cookie based)
http://devcentral.f5.com/wiki/default.aspx/iRules/ASP_SessionID_Persistence.html
i can see f5 get sessionid's and add age correctly but LB not working properly, some times i can see f5 load balance connection to each server but sometimes not!!
i cleared all persistence records (b persist all delete) and connections (b conn all delete)
then i tested 5 new client machine each clients load balanced to same server
What can be problem , why this irule interest client ip and port ?
i didnt understand two lines in this code it start "debug"
set cli [IP::remote_addr]:[TCP::remote_port]
set SessionId [HTTP::cookie ASP.NET_SessionId]
if {$::debug}{log local0. "Client: $cli Request SessionId: >$SessionId<"}
if { $SessionId != "" } { persist uie $SessionId 1800 }
when LB_SELECTED {
if {$::debug}{log local0. "Client: $cli LB to: [LB::server addr]"}
regards
zafer
  • hoolio's avatar
    hoolio
    Hi Zafer,
    In addition to Stefans helpful comments, it looks like you're missing the section of the iRule where the response cookies are parsed for the ASP session ID. Without that, the second request would not be persisted to the same pool member as the first:
     when RULE_INIT {
       set ::debug 0
     when LB_SELECTED {
     when HTTP_RESPONSE {
       if {$::debug}{log local0. "Client: $cli  Response SessionId: >$SessionId<"}
       if { $SessionId != "" }{ persist add uie $SessionId 1800 }
    Aaron
  • zafer's avatar
    zafer
    i got application error when i use two server in pool
    i found same issue from google but i dont know how can i fix it
    http://www.tech-archive.net/Archive/DotNet/microsoft.public.dotnet.framework.aspnet/2006-07/msg01538.html
    http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=1090433&SiteID=1
    http://www.element-it.com/System.Web.HttpException-Request-timed-out.aspx
    regards
    zafer
  • hoolio's avatar
    hoolio
    Hi Zafer,
    It looks like the three articles you linked to refer to a few different application errors. What is the actual error you see with two members in the pool? With the full codeshare example, do you see clients being correctly persisted? If you're seeing persistence failures, can you change to source address persistence and see if the application errors are fixed? If so, it would seem the errors are related to persistence.
    Aaron
  • zafer's avatar
    zafer
    Hi Aaron,
    first of all i dont understand something this is strange.
    i put on production and it worked 20-30 minutes, after that we saw application error then i took tcpdump and removed second member from pool
    we checked dump and persistency records, it works correctly but we see still errors.
    we hava invaliv view state error
    http://support.microsoft.com/default.aspx?scid=kb;en-us;555353&sd=rss&spid=6351
    i can not use source address persistency because clients comes with natted ip address.
    regards
    zafer
