vishu_chavan's avatar
vishu_chavan
Mar 17, 2022
Solved
Yahoo mail issue due edns
From last 2 month we are facing Yahoo mail issue .we can't receive Yahoo mail to our domain,same was reported to Yahoo .
Yahoo support reported that our domain edns1 is time out.
Currently our F5 was running on 11.5.1 version and as per article ..edns work around is available in 11.5.8,
So we update F5 version to 11.5.8. but still
We  didn't get prefer client subnet check tab.
Kindly suggest work around for edns on version 11.5.8
Article link
https://community.f5.com/t5/technical-articles/using-client-subnet-in-dns-requests/ta-p/282196
Thank you
  • Hi vishu_chavan,
    I have a couple of ideas that you might need to check. Are you using ZoneRunner (Local BIND) at all, or is all of your DNS traffic just going to Wide-IPs? Do you get positive results from the ISC genreport tool or the ISC EDNS compliance test website? https://ednscomp.isc.org/
    I'll assume you saw the relevant KB, but i'll paste it here: https://support.f5.com/csp/article/K07808381
    Unfortunately the 11.x branch is quite old, is there any possibility of upgrading to a later version?
    Thanks,
    Josh
  • HI  josh
    Thanks for adivise .We upgrade to 11.5.8 version and issue resloved.
    Thanks you
  • Hi vishu_chavan,
    Thanks,
    Josh
  • HI  josh
    Thanks you
  • - If your post was solved it would be helpful to the community if you selected *Accept As Solution* on the relevant reply (or replies). This helps future readers find answers more quickly and confirms the efforts of those who helped.
    Thanks for being part of our community.
    Lief
