Technical Forum
Wss traffic not going through when html profile in use
Dran
Hi Team
Hope everyone is doing well. I have a setup of F5 asm n f5 ltm and application uses wss protocol after initial login. I am using html profile n stream profile to manipulate the html contents of html page. And when using ltm alone with just wss profile and asm, everything is working but when I add the html profile where I have chose to remove some of the tags and stream to replace some of the strings, but we do want to apply asm on the wss content as well, so dnt want to remove http profile when wss upgrade header is seen. And I did try applying html profile to the login page alone by fetching the uri from request and checking it in response but for some reason, after login where wss protocol upgrade takes place, the application doesn't work.
0 REPLIES 0
