23-May-2003 09:10
I wsdl utility found in Visual Studio .NET 2003 to compile the wsdl files found in iControl WSDL v4.5. During the course of the compilation into either C or VB .NET languages, there are several warnings depicted below. Could someone please assess this issue and provide comments on its impact?
Schema validation warning: Namespace 'http://schema.xmlsoap.org/soap/encoding/' is not available to be referenced in the schema.
WSDL command invoked:
wsdl /l:vb /n:ITCMSystem.SystemInfo ITCMSystem.SystemInfo.wsdl /o:ITCMSystem.SystemInfo.wsdl
Best regards,
Gary Chen
28-May-2003 09:10
There is no information on this warning (at this time) in the Microsoft knowledge bases. It has been verified that these warning have to do with using the SOAP v1.1 schema encoding and an issue wsdl.exe's parsing of them. The same behavior can be seen by compiling several wsdl documents available from http://www.xmethods.com as well.
It has been verified that these warnings are just informational and the correct generated client code is generated and functions properly.
When all the supported client toolkits include support for SOAP v1.2, we will move to the new encoding schema and this should remove the warning messages.
19-Sep-2007 16:37
