Technical Forum
wildcard parameter name match on numbers
Mohanad
Hello Everyone
I'm trying to create wildcard parameter name match on numbers on url level, for example param names 9, 92, 662 & 1165
I created parameter name to match parameter with 1 digit [0-9] and [0-9]+ to match any number of digits, and also tired to add /[0-9]/ but both doesn't work.
can anyone guide what is support format by f5 for regex
Thank you.
1 REPLY 1
ragunath154
Cirrus
Cirrus
9- [0-9]
92 - [0-9][0-9]
662- [0-9][0-9][0-9]
1165- [0-9][0-9][0-9][0-9]
these works fine, make sure the parameter type is set to wildcard.
