19-Jun-2020 10:00
I have enable java script in my browser , but sometimes I'm receiving white page and when i check the developer tool the message says:
<noscript>Please enable JavaScript to view the page content.<br/>Your support ID is: 5524241599271179563.</noscript>
what is the root cause of this ? and how to solve it?
#ASM #application_delivery
21-Jun-2020 07:02
Two things you may want to check:
1) Is session Tracking, Awareness enable? If yes, turn them off.
If then after disabling the above, you still see white page, then check if you application is SPA. If so, then, enable SPA
2) enable SPA:
Security ›› Options : Application Security : Advanced Configuration : System Variables
Look for single_page_application
Enable it
Note: You must perform a 'tmsh restart sys service asm' for this change to take effect! If you are using a device group you must perform 'tmsh restart sys service asm' on all members of the device group for this change to take effect!
If you still see a white page, open a support case.
16-Jul-2020 02:07
I have turn off session traffic , but the issue still.
what does single_page_application mean?
16-Jul-2020 02:08
unfortunately , i could not found any logs related to that support IDs , even i have tried with real time support id but with no result
