neeeewbie's avatar
Oct 28, 2021
which way correct ? for disable syncookie protection
which way correct for disable syncookie protection ?
Hi guys
I met some problem. some traffic as a DSR. so we need disable syncookie protection.
I chage value global option like Default Per Virtual Server SYN Check™ Threshold, Global SYN Check™ Threshold is 0
and I configured disable Hardware VLAN SYN Cookie Protection
but I have some question.
Does not work these three option (software-syn-cookie, syn-cookie-enable, hardware-syn-cookie) If I turn off the global option?
ps. software-syn-cookie, syn-cookie-enable, hardware-syn-cookie options in fastl4 profile
thank you
